02-12-2008, 02:56 AM | #1 |
Junior Member
1 piece driveshaft
Can I run one on a LWB truck? I changed the SWB with no probs just not sure about the LWB. I have an absolete carrier bearing and would rather just change the shaft than modify the carrier bearing set up.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-12-2008, 05:21 AM | #2 |
ran out of money
Re: 1 piece driveshaft
lwb normally have to long of a stretch to use a 1 piece without having problems.... the shaft will actually start "whipping" because the length is to long. imperial driveline sells both styles of center bearings. i have a 71 lwb and kept blowing up napa bearings i switched to theres and have not had a problem.... and that truck is abused regularly.
if you dont mind me asking where did you get the 1pc shaft for you swb? i just swapped a bbc and th400 into my swb and need a shaft (sorry i dont mean to hyjack your thread) thanks and hope that helps 71rat
Modify everything, leave nothing alone!~ |
02-12-2008, 05:25 AM | #3 |
ran out of money
sorry i messed up the name of the company is "inland empire driveline" here is a link to their center bearings
http://www.iedls.com/bearings.html
02-12-2008, 09:22 AM | #4 |
Junior Member
I had the SWB custom made and the LWB uses a carrier bearing that is obsolete.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 02-12-2008 at 09:23 AM. Reason: spelling |
02-12-2008, 09:32 AM | #5 |
The 72 frame I just got had a i piece drive line custom made by Six states here in Idaho. It was a lwb truck. The transmission and transfer case were moved back 6 inches, so the guy had to shorten the drive line and went with a one piece. My 67 lwb has a 2 piece in it. So I guess it can be done, don't know why not other than like 71rat said, whipping will occur with too long a shaft.
1969 4x4 Nothing beats a good rock drill and some dynamite |
02-12-2008, 09:41 AM | #6 |
Just like to part out trucks!!
I parted out a 67 gmc with a original one piece driveshaft in it, had a turbo 400 tranny going to a dana rearend
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
02-12-2008, 09:45 AM | #7 |
Junior Member
Randy was yours a LWB truck? This one is LWB turbo 350 truck. Thanks
02-12-2008, 09:48 AM | #8 |
Yes it was a lwb, I forgot to add it had a the 351 V6 motor too
02-13-2008, 07:39 AM | #9 |
Junior Member
Anyone else running one on a LWB?
02-13-2008, 08:12 AM | #10 |
Out of the carpool lane.
I ran one for years on my L6/3spd LWB truck. After going through carrier bearings on an annual basis, I got sick and tired of it and went with a 1-piece shaft through Six States here in Portland. I never looked back and it served me very well for a number of years.
With proper setup, a carrier bearing can work very well for decades, however the cheap crappy ones you find at most LAPS won't last very long. They're made overseas and only spot welded and any slight separation will cause the rubber to begin spinning in the housing making it deteriorate rapidly. If at all possible spare no expense when setting up a new carrier bearing and hopefully it'll last you for another 40 years. However, I didn't want to take that chance and decided to be over and done with it and pay $175 and a few hours time and KNOW that I wouldn't ever have any more problems.....ever.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
