K & N Filter
My grandparents neighbor gave me a K & N Filter and the chrome breather for a 350 4bbl since he'd never use it agian since he no longer has anything that would use it. I just wanted to make sure if this was one by compareing of a pick of another one. Also are these good to use on gravel since the holes are so big and do they let dirt in? Tell me what you think of them, before I put it on.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
Fabricate till you "puke"
I have a 14x4 K&N on the longhorn, & due to the tilt front end, it runs in a dustier enviroment. I plan to add a prefilter to help the situation, & would reccomend it on gravel roads. Check into Summit, or Jegs for the prefilters(just a foam sock to rap the element. the beauty of the K&N is that it can be cleaned & reoiled. The initial cost seems a little high, but with 14" open elments @ $8-9 a pop(paper), it doesnt take too long to pay for itself. to answer the Q, I dont think it will be a problem running the filter in gravel..........crazy AL
Oops, here is a link.... http://store.summitracing.com/partde...57#largerimage
Getting cabin fever?!?!?!
i.ve had k&ns in my last 2 trucks and my wifes car and had no problems. the oil seems to grab the dirt and hold it. if your worried about dirt getting in you could wash it a little more frequently. ive had no problems. my buddy runs one on a bronco II with a 5.0 and 38's in mud runs with no problems. that thing comes home covered in mud. i say run it. you may even get a little hp boost as well. jmo tho.
oops can't type
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
Actually, K&N recommends against too-frequent cleaning because they depend upon the dirt to do some of the filtering!
K&Ns research shows that they pass 1-20 micron particles. K&N won't tell you how this compares to paper filters, but it isn't good. Even Fram filters do better than that. IMO, K&N is one of those products that has too much marketing. Their ping pong ball demo, if you have ever seen it, is extremely misleading. Without working over the ENTIRE engine, removing one restriction (that isn't really all that significant) will not make any difference. |
The dirtier the situation the better when it comes to K&N filters.
Pre oil the filter to prime it so to speak, oil attracts dirt, as the dirt/dust particals build up the filter becomes more and more efficient. If you like you can even run a pre filter (sponge) which doesnt do much good unless your into off roading or dirt track racing where there are large particales that could clog the filter. I definatly would run a KN if you already have it. I put on one every performance vehicle I have. There's a reason most of your racer's (nascar/dirt track/drag strip or where ever) use K&N. ![]() |
Do keep in mind that what "racers" do is not necessarily what is best for your truck.
Especially, wear and risk to the engine are both much less of a concern. A race engine doesn't have to last 100K+ miles. A street engine doesn't have to rev up to 8000+ RPM. They are different. If your goals happen to match up with a racer, than maybe matching choices is called for. But if you ONLY drop in a K&N, you won't do anything. Race engines are engineered so that flow is maximized throughout the engine. This is an exceedingly important step. For instance, improving the intake without porting the heads will just increase the (absolute) pressure in the heads. |
Formerly yellow72custom
I have a K&N filter in my 14x3 open element chrome air cleaner. I like it alot. I was able to get a deal on one at O'Reilly's for $36, not too bad considering they are around $45 from Summit. It's great when you are friends with everyone that works there
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#9 | |
He asked opinions on an air filter he recieved.. my advise is still the same. USE IT, and never buy another paper filter again. enough busting balls over an air filter. |
![]() Join Date: Dec 2001
^what he said. I have better mileage with the K&N and I am not imagining it.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
My other Love
Its mostly marketing. Same with fram, anyone ever taken apart a fram oil filter and compare it wit a premium napa oil filter, the napa filter is by far better and is the only oil filter that i will run on any of my vehicles
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Used to have a truck
Was it Hot Rod or PHR that did an article on K&N a few months back ? Actually it was performance filters in general. I believe the consensus was that they didnt gain any HP with the K&N versus a paper Fram filter.
Personally I'd rather change the paper filter every year or so than go through the pain in the ass of cleaning and oiling the K&N on a regular basis especially given the fact I have never kept a completed project more than a few years and yes I have used them before. I still like the look of a fresh paper filter over the off yellow color of the K&N.
No truck :-( |
