02-12-2008, 05:39 AM | #1 |
ran out of money
what radiator you guys using? BB guys?
hello all,
I need to find a nice rad. that fits well and will be able to cool my built bbc even in the middle of summer. Im going to be using dual electric fans but need to be able to keep my motor under 170* what do you guys think of the be cool rads besides price? anyone have one? hows the fit and finish? my options i figured are: 2 core high flow aluminum rad. or 4 core copper rad. Just looking for something to fit like stock and keep my built bb cool Thanks 71rat
Modify everything, leave nothing alone!~ |
02-12-2008, 07:42 AM | #2 |
I am a Referee of life.
Re: what radiator you guys using? BB guys?
If I built a BB and wanted a new radiator,I wopuld look for a 4 core aluminum.I would also use an electric fan set up.Even though that's an expensive option,I think after spending the $$$ to build a BB I would want to protect my investment.
I don't have any experience with the Be Cool's but they have a great rep just kinda pricey.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-12-2008, 11:18 AM | #3 |
ran out of money
i dont know of anyone who makes a 4 core aluminum rad. also with aluminum rads they normally have more cooling tubes and fins the problem with going to a 4 core is there is to many cooling fins that it actually hinders the air flow and cooling
Thanks for the idea though
02-12-2008, 11:31 AM | #4 |
mines the original 4core brass unit and it keeps mine cool. But i think id rather have an aluminum but not sure if it would cool as good as this old 4core or not. I also have one electric fan behind it.
02-12-2008, 12:06 PM | #5 |
ran out of money
69trk, nice thanks for you input.... did you ever get around to putting a cage into your truck?
02-12-2008, 12:21 PM | #6 |
The Older Generation
I have a refurbished, stock four core radiator with a stock fan in the white truck and had some issues until I put a fan shroud on it. After that no more issues... 170º seems a little cool to me. A local mechanic recommended I use at least a 185º thermostat in mine (454, mild cam/th400). LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-12-2008 at 12:22 PM. |
02-12-2008, 02:22 PM | #7 |
I've got a 454, 4 core, and Lincoln MK8 fan. So far, so good. Last summer was no problem. This summer we'll see since I have my a/c up and running now.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-13-2008, 12:16 AM | #8 |
I'm using a stock heavy duty 4-core from GMC Paul's. I have a stock 350 with a 180 degree thermostat. I don't race but I'll tell you what- I can run at speed limit (or as close as she can make) all the way up Arizona mountain grades, in summer, a/c full blast, with my boat in tow and never worry about the temp. gauge. You should be ok in Jersey with that.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 02-13-2008 at 12:23 AM. |
02-13-2008, 02:16 AM | #9 |
I have an aluminum Griffen in mine and haven't had any problems. It fit perfectly except I had to get new brackets and carriages because I had a 2 core in it. You can easily get them from the vendors, LMC had the cheapest prices at the time.
1968 C10 Stepside 396 bored .030 TH400 |
02-13-2008, 02:45 PM | #10 |
Have a stock radiater in my 70 with 454 --- stays at 185 - 195 in summer in az -- even in town with AC on! Run stock clutch fan with shroud. Big blocks need a little heat for best performance.
02-13-2008, 03:05 PM | #11 |
This set up is your best bet. Factory crossflow for BBC and fan shroud. Also another thing to remember is in order for the fan shroud to work properly the fan must be positioned 1/2 way in the fan shroud. In other words if you sighted down the fan shroud looking from the top the fan shroud would dissect the fan blades in half. If the fan is to far in or out it will not perform to its peek.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
02-13-2008, 08:20 PM | #12 |
ran out of money
thanks everyone for your replys looks like a stock 4 core is my best bet... im going to run the dual electric maxima fans. with my long water pump i dont have much clearance.
thanks again for everyones input
