02-12-2008, 11:36 AM | #1 |
stepside bed install question
Hi,
I just painted the bed and put it on the truck but it looks like it's sitting low, I have 3/4 inch spacers in on the front brace to take the space of the wood bed, are there spacers that go between the frame mounts and the cross bars on the bed? Is it normal to have to "adjust" it up a bit?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
02-12-2008, 12:15 PM | #2 |
Re: stepside bed install question
There's no spacers, I've seen some trucks with a rubber pad under the bed mounts though. Why do you think it sits low?
Also I'm pretty sure that the stepside beds are not as tall as the fleetsides in relation to the back of the cab. |
02-12-2008, 12:54 PM | #3 |
yeah they sit lower. the bottom of the step will be right below the cab
02-13-2008, 09:43 AM | #4 |
Looks good at 20-ft .....
If this helps......... Stone-stock & never off the truck:
02-13-2008, 09:46 AM | #5 |
Damn Yankee
I thought there were wood spacers from the factory (squares with bolt holes in them)....but I'm somewhat senile
