Old 02-12-2008, 11:50 AM   #1
rmorelan
new parts outlet
I'm doing some research on a 72 blazer. Looking for replacement drivers and passanger floor pans and also rear floor of bed floor. Does anyone kow a good outlet to find these parts? Are they even reproduced? I would be happy to speak with someone who may have a decend blazer for parts. I can find then for pickup.
rmorelan is offline   Reply With Quote
Old 02-12-2008, 01:10 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: new parts outlet
You'll find a list of great vendors here.
Blazer doors are being reproduced. You'll need to either find a donor Blazer for the rear floor or adapt a pickup floor to fit.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-12-2008, 01:35 PM   #3
rmorelan
Thanks for the info. I have an ok long bed floor, didn't know if I could make that work. Was also wondering if front floor pand for a pickup are the same as the blazers?
Old 02-12-2008, 01:59 PM   #4
bouncytruck
SKINNY TIRES RULE!
The truck floor pan (assuming you're talking about the whole thing) is probably a bit longer behind the seats as the blazer has the step up to the bed. Also, a 4wd Blazer should have the high hump over the transmission/transfercase. Separate patch panels are available for Blazer and Pickups.
Someone just replaced the bed floor with one from a pickup. I think it was VTblazer, but I can't remember for sure. Hopefully someone will correct me.
bouncytruck 1972 K5
Old 02-12-2008, 08:22 PM   #5
vtblazer
vtblazer's Avatar
As good as you'll find right here:
http://www.tri-proautomotive.com/servlet/StoreFront
vtblazer is offline   Reply With Quote
