Old 02-12-2008, 12:07 PM   #1
RMATTZZ4
Welding question..
When welding sheet metal which size of wire would be recommended? .020, .030? Does wire size make a big difference in the settings on the machine?
Is it easier to weld sheet with smaller wire(less heat?)? I have a handler 130 mig welder and am going to get busy, just have a few???
Thanks, Rob
RMATTZZ4 is offline   Reply With Quote
Old 02-12-2008, 12:13 PM   #2
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: Welding question..
Your best bet is the thinner wire, larger wire diamater means more heat to melt it, more heat means more possibility of welding. Also you need to be aware with your welder, it is a smaller welder and has a lower duty cycle.
The thing is if you run it too long it will not produce the same voltage (a mig welder is a CV or Constant Voltage machine), when the voltage starts to fluctuate you will get bad welds. Also id get some old body pannels from a body shop in your area and cut them up and practice on them so as that you can get it down pat before you start welding on somthing you really want to keep.
Wire feed welding is about the easiest process to learn, pay attention to what wire speed you need for what heat setting, and play around with it some, then you will get it all figured out.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 02-12-2008, 12:19 PM   #3
RMATTZZ4
Thanks!
Old 02-12-2008, 12:23 PM   #4
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Originally Posted by RMATTZZ4 View Post
Thanks!
If you have any more welding questions feel free to bounce em off me, I am going to school for a degree in "Metals Technology" or in other words it is a fluffed up way of saying that I am going for a weldign degree.
