chevy only
![]() Join Date: Sep 2006
any tips on changing p/w motors
getting ready to change the old 30 year old p/w motors, mine still work but they are really sloooooww, got some new ones coming in monday, if anyone has any tips please let me know, thanks dino
CHEVY ONLY... Nothin Else ! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: any tips on changing p/w motors
Dino,... check this out from www.73-87.com. http://www.73-87.com/7387garage/interior/winmotor.htm Use plenty of grease on all the moving parts. This link helped me alot.
chevy only
mr lowlife,thanks for the help,that is some good info, thanks again
Dark Heart Motorsports
I cut a hole in the bottom of each of my doors... about 5x7 inches...
also allows me to put 6x9's there when I get them ![]()
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
Parts and more parts
The most important thing is that when you are ready to take that motor off of the regulator assembly----MAKE SURE that you have a hole drilled through the assembly mounting bracket and the window regulator gear. You will want a 1/4" bolt through that gear and mounting bracket to hold the spring tension. Your fingers and mind will thank you.
Before changing the motors out you might try and just grease the hell out of everything first.
On my '86 it was a ***** to roll up the manual windows. Pulled the panel and greased the channels real good and now they are butter. Since you aren't the muscle with power windows you don't feel just how hard the motors are working. Might be able to prolong the life of the motors for a while anyways.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#7 | |
chevy only
#8 | |
chevy only
