What to paint frame with?
What do you guys recommend to use for painting my frame? POR, Powder Coat, or Spray paint? I am not looking for the shinny look i want a mat finsih look. Pictures of what you recommend would be good?
Thanks |
Questionable
Re: What to paint frame with?
You have several options. Are you sandblasting?
If you are, consider powdercoat. Powdercoating is hard as nails, wont chip or flake if done properly, and is a lifetime finish. Way better than automotive paint. If you are not, and just plan to paint, Eastwood has several products such as "Rust Encapsulator" which is easy to apply. POR-15 is another viable option. I've seen some guys here on the forum use a newer product called "Rust Bullet" (it's silver and looks badass in pictures) which is similar to both Rust Encapsulator and POR-15 Make sure you read the instructions on whatever you choose, and wear nitrile gloves or similar. Do not leave the can open. POR-15 is supposed to harden instantly on contact with moisture, so ... it sticks to skin and you can ruin a whole can if you leave it even cracked a smidge.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-13-2008 at 01:22 AM. |
Active Member
![]() Join Date: Jul 2007
I used Rustoleum on on of mine about 10 yrs ago and it's still holding out pretty good.
POR15 is a good product (pricey) and I've used it on other parts. The only thing I don't like about it is that if you get it on you, it's hell getting off once it dries... It's almost like a tatoo... |
Yes i will be sandblasting
![]() Join Date: Apr 2005
I POR 15 all my frames, (they are not for show, just don't want them to rust,
![]() R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Just remeber por 15 is not uv resistant you will need to clear over it or it will turn foggy..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
The Older Generation
Here's a thread on POR-15 where I posted some of my observations after doing my chassis.... http://67-72chevytrucks.com/vboard/s...ghlight=por-15 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-13-2008 at 03:49 AM. |
Can you repost the link, it's not working. Well, at least not for me,
#10 | |
LockDoc
Sierra Grande Club
If you want something that will hold up well, and is cheap, and you mentioned matt finish- use John Deere Blitz Black paint. Google it (looks very appealing). It says it easy to touch up too; the one thing powder coat can’t do……
I think it like $17 a quart. I found this the other day searching JD lamps for my Land Cruiser and it defiantly has my attention! Hope this helps. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Skinned knuckles
What about Hammerite? I painted the back half of my longbed frame with it a while ago. It's pretty tough and covers any rust well. The only reason I'm not using it now is because the short frame I'm doing is really clean and I don't need to cover any perfections with the hammered texture.
I'm using Rustoleum Professional in the spray can now. The area I cleaned and painted the other day held up really well to the laquer thinner that I used to wipe the frame down when I finally finished cleaning it.
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) ![]() '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
#13 |
Self-proclaimed LED man
Definately Por-15 chassis black. Looks good and will never rust again.
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
#14 |
I was going to give this stuff a try http://www.nomorerust.com/ Msgross used it on his biuld check it out here . http://67-72chevytrucks.com/vboard/s...=242910&page=3
Earl 68 2500 4x4 GMC Burb |
#15 |
I will be using Rust Bullet when i tear my truck down to the frame....
-wes |
#16 |
Questionable
Here is a post on Rust Bullet, since it seems to be pretty obscure:
http://67-72chevytrucks.com/vboard/s...&postcount=113
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#17 | |
Used the pm industries coating system on mine too and am very happy with it.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited Last edited by Ace in the hole; 02-13-2008 at 06:15 AM. |
#18 |
there is a place in gainsville that can powdercoat the whole thing if you dont have any one in mind to do the work, they preheat the frame then powdercoat then cure. most people will tell you that is a waste of time THEY are usually the ones doing the powdercoating (lazy) and they dont want it to last that long I guess, job security.
the thing with powdercoat is you cant have anything on the frame it has to be clean, i have not seen powdercoat on a frame that has not chipped. i usually mar hyde one step the frame then shoot S/S black and i can reshoot chips and scratches anytime. you will notice people from all over the country have different ideas of what to do with their frames. When was the last time you got snowed in? or the snow caked on your truck took two months to thaw out? |
#19 |
I have had good results with GM reconditioning paint. $35 a gallon at your local dealer. Sandblast, open the can, stir, pour it in your paint gun. No priming or mixing and it has a geat satin finish.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
#20 |
Sierra Grande Club
I definitely like the rust bullet. I’ve used POR15 and don’t like it so much. There is a ton of prep work for the stuff too. Although I haven’t done any touch up, it seems like it would be a pain.
I have to admit that the JD paint looked like it would be easy to use. Tractors aren’t generally babied either. Here is some good info about with pictures…. http://crankshaftcoalition.com/wiki/...tz_Black_paint s/t
#21 |
Go to tractor Supply and buy their Rusty Metal primer and their Low Gloss Black Tractor Paint (add the hardener) and you get a real good result. In my opinion.
Here are some of my truck doing this. ![]() ![]() ![]()
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
#22 |
Close up: Was put on with foam brush and flowed out real good
#23 |
Notice in the picture above it looks cloudy because my garage is real dusty.
It looks real clean when brushed off
#24 |
I used Rustoleum, sprayed it with my cheapo gun, only had gloss, next frame I'm doing is a satin, should look better.
Kinda dark in shop, but looks good to me.
1969 4x4 Nothing beats a good rock drill and some dynamite |
#25 | |
LockDoc
