Heater control box lighting
Well this is actualy 2 quwestions in one. I found a small light gauge grey wire dangling from the wire harness adjacent to the ignition switch heater control box. I spent some time searching here and found a wire diagram that shows a grey wire for a light in the heater control box...... can someone confirm this?
Also , where can I buy the light bulb holder for the instalation into that box where the controls are mounted???? Thank you.
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: Heater control box lighting
If I'm not mistaken, the grey wire feeds the bulb in the back of the heater controls (on the dr. side behind the choices) - you might find the bulb and holder still there.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
my bulb and whatever holds it in are gone from the control box....... I am actualy about to rebuild the control assembly that all of the rivets have let go.
so besides a wrecking yard.............slim chance to none................where could one be purchased?
auto parts store. i just picked one up. they look a little different than stock, but still work well.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
I'll give em a try....
thanks a bunch!
