10-22-2002, 02:56 PM | #1 |
Just Another Crazy Canuck
1/2t to 3/4t cab swap ???'s
what else besides the cab mount bushings is different?
once I get the mounts I should be able to just slap my cab on the 3/4 frame right? or is there more that needs to be changed what is the difference between 1/2t and 3/4t cab mounts?
1985 454/465/205, 38.5x11-16BOGGERS soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
10-22-2002, 03:03 PM | #2 |
Fabricate till you "puke"
The cabs are the same, just the rear cushions are heavier, & the brackets for the cushions are mounted lower on the 3/4 ton....just use the cushions for the 3/4 ton frame, & you should be ok. crazy longhorn
10-22-2002, 03:17 PM | #3 |
so only the rear mounts are different and I can use my 1/2t front and rad support cushions?
cos I got the rear ones are still on the frame
10-22-2002, 03:36 PM | #4 |
Im not positive on the front mounts, but beleive they are the same on both 1/2 & 3/4......the rear mounts are about 3 times as tall on the 3/4(a little suspension on the cab, to smooth the bumps!)......crazy AL
10-22-2002, 03:45 PM | #5 |
Yeah it's only the rears that are different.
71 GMC 1500 LWB |
10-22-2002, 05:25 PM | #6 |
You didn't mention if the 3/4 ton was a 4x4 or not but just check to see that the transmission humps are the same.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
