Active Member
![]() Join Date: Jul 2007
Windshield compatibilty question... are they all the same?
I was looking at a 71 or 72 chevy truck in a junkyard that was stripped to the core but had a nice tinted windshield with the chrome on it... Since the one on my 69 Chevy is broken I want to buy it if it will fit. Mine is a plain C10 without tinted windshield. Thanks for info...
Re: Windshield compatibilty question... are they all the same?
99.9 percent positive there is no difference in the glass from 67 to 72, so I believe it will fit.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
Active Member
That's about what I figured, but since it was a fancier chrome trim, tinted one, and mine is plain vanilla, I wanted to make sure. I'm going to try lockdocs method for removal. I'll probably use silicone oil spray on it though.
http://67-72chevytrucks.com/vboard/s...ght=windshield Lockdoc, if you see this, what was your install method? The reverse of the removal? Thanks. |
#4 | |
Engine n00b
I found this: http://www.ecklerstrucks.com/product...dept%5Fid=1473 Looking for cheaper or opinions though - im not in a hurry to swap mine - might just wait til I break, chip or crack it to fix. |
Active Member
http://67-72chevytrucks.com/vboard/s...shield+removal
Here's lockdocs method again. I found another guy used stiffer tongue depressors to hold the rubber down when it's cold. Anyway, looking at the eckler's ad, it does say 67-72.. I was concerned that when you order, sometimes they want to know the year and make, etc and then send you the one for your truck... Thanks for infor.. |
![]() Join Date: Feb 2006
67-72 windshields are all the same for pickups and c50 trucks. good luck getting the used one out without breaking, take your time. If you need a new windshield the part # is DW 685
BlahBlahBlah
I think there are two different window trims. One goes a little deeper in the gasket channel. So if you mess up the gasket make sure your new one is the correct one for your trim.
#8 | |
The Older Generation
http://67-72chevytrucks.com/vboard/s...ad.php?t=90510 When you remove the windshield it is very important to keep even pressure on it and space your hands out. If the rubber seal is really hard you are better off cutting the seal and getting a new one. It should be pretty easy to peel it out far enough to get the hose and elect. cord in. Again, don't get in a hurry. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-13-2008 at 02:59 PM. |
![]() Join Date: Sep 2007
,68gmsee,
I just pulled the window on my 68. It's really not worth trying to reuse the original seal. It's stiff and will most likely cause the window to crack if you try and pull it. Razor knife off the inside of the seal and then push it out, have a friend or two to help you lift it up once you get the top to come loose from the channel. Don't try to fold it out to the hood you could bend and damage the lower lip. Also a new seal will make the install and sealing portion much easier. Good luck... |
Active Member
Thanks all for the input..
I believe that I'll just cut the old seal off after what I've read from you all. This truck has been sitting in the hot Texas sun for a long time and I'm sure the seal is rock hard... |
