Old 02-13-2008, 10:31 AM   #1
ElkyRacer
Another way of doing a watts....
I saw this on another board. Seems like guys are always trying to figure out how to do a watts style linkage on a 10/12/14bolt style diff with a cover, why not do something like this? Wouldnt it work just the same? Less to engineer around since it doesnt mount off of the center of the rear end, normally where the cover is.
Kyle
ElkyRacer is offline   Reply With Quote
Old 02-13-2008, 11:05 AM   #2
EyeH8the24
EyeH8the24's Avatar
Re: Another way of doing a watts....
looks nice would like more pics of the set up...but looks like it would be stronger than one that used the cover bolts to mount up
EyeH8the24 is offline   Reply With Quote
Old 02-13-2008, 11:56 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
That's actually the way a Watt's link is supposed to be set-up. What most people are familiar with is a modified version that has been developed to bolt-on.
The rear roll center is located at the center of the watt's pivot... making it desireable to have that location on a fixed part of the chassis vs. the differential.
As mentioned... seems easier to have it set-up this way as well...
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-13-2008, 01:02 PM   #4
SCOTI
SCOTI's Avatar
So the watts 'mount' is fixed w/the frame & the links are attached to the top (one side) & bottom (other side) of the rear housing/suspension.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2008, 01:05 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
pretty cool... i would rather be able to see the actual links from the rear view though
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-13-2008, 01:10 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
That way, when the suspension goes through its travel the roll center doesn't migrate as much as it would IF it were attached to the differential.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
