Old 02-13-2008, 11:16 AM   #1
chrislehr
Engine n00b
chrislehr's Avatar
Lighting question and a door question - is this the norm???
1970 Custom 10.
I have the floorboard high beam selector, and it seems to have 3 instead of the usual 2 settings.
It has parking lights, low beam, and high beam.
Let me tell you, when going 70 on a highway at night, hitting the "parking light only" one was a true shocker. Is this normal, or is mine jacked?
Also - on the doors. We cannot lock them, then close. We HAVE to close, then use a key to lock.
Is this the norm on both? Anyone?
chrislehr is offline   Reply With Quote
Old 02-13-2008, 11:21 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Lighting question and a door question - is this the norm???
These trucks require a key to lock the doors. I guess too many people were locking the keys in their trucks? As for the floorboard switch, I've never heard of one that operates parking lights. I think you have a short/bad ground, something wrong electrically. Someone else will chime in with more info I'm sure.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-13-2008, 11:26 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The door locks are normal.The lights on mine did the same but intermittently.I replaced the dimmer switch and everything worked(not the door locks).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-13-2008, 11:29 AM   #4
463
463's Avatar
the dimmer switch has been altered or screwed up. just swap it out and you will have it fixed. as for the door locks i believe that it was later models that worked that way. to slow a on the keys
463 is offline   Reply With Quote
Old 02-13-2008, 11:44 AM   #5
chrislehr
Engine n00b
chrislehr's Avatar
Cool, adding dimmer switch to the shopping list. I found a bunch of wires hanging under a bumper too for the lights/towing and now I am thinking a new wiring harness really might not be a bad idea at all!
