how is everyone? i´m a junior member in the navy on an excercise in denmark and i couldnt stay away from this site. anyway i just bought(before i left) lowering spindles for my 3/4 ton suburban. the spindles are 1/2 ton and require 73 and up ball joints. i would like to install disc brakes. i have an ambulance with a rear6 lug axle how do ikeep all 4 tires 6 lug
thank you |
huh?
![]() Join Date: May 2000
6 Lug Rotor & Hub Assembly
Each 692989 6-Lug Front Disc Brake Rotor & Hub assembly. Will work on 1971 up standard truck spindles or when using our drop spindles. These are 100% new true 6 lug rotors manufactured in the USA, not the inferior 5 lug rotor that has had plugs installed in original holes then redrilled for a 6 lug pattern as many sell. $84.95 That's straight off of GMC Pauls site. Here's the link, that item is about 1/2 way down the page ![]()
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Recovering Truck Driver
welcome to THE board!! i dunno anything about drop spindles though! lol
------------------ Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s Angel girl: 67 Cutlass convertible 330, 3spd stick Greener: 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE no name yet: 72 442 under serious construction my site: http://communities.msn.com/Beastonabudget/homepage
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Welcome...and did someone give you your email name or did you pick it yourself. I got a chuckle out of it.
------------------ Orlando,FL 72 Chevy 4x4 3/4T CustomCamper w/SB 406
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
