Old 02-13-2008, 01:40 PM   #1
Dads 68 GMC
Dads 68 GMC's Avatar
Auto tranny linkage help, PLEASE!!!
Name:  GMC parts 018.jpg
Name:  GMC parts 020.jpg
I switched from a manual to an auto trans. I took the pivot bracket off a 1968 c-10. I think the bracket off of this 2x4 might be different from a 4x4. my frame does not have the holes I need, do I need to drill 2 holes and get a different bracket? if so does someone have the bracket I need? I can do paypal or whatever you need, Thanx,Philip
Dads 68 GMC is offline   Reply With Quote
Old 02-13-2008, 02:16 PM   #2
ckhd
ckhd's Avatar
Re: Auto tranny linkage help, PLEASE!!!
You should think about the linkage kit from bowtie overdrives.
http://www.bowtieoverdrives.com/cata...php?ITEMID=193
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 02-13-2008, 02:23 PM   #3
krue
Designated A-hole!
krue's Avatar
I'll try to remember to go look on my 4x Blazer and see what bracket it uses in the morning.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-13-2008, 02:31 PM   #4
FLEET72
FLEET72's Avatar
I have that linkage on my 72, bought it direct from Kugel. The 1 drawback is that it does not isolate motor torque from being transmitted to the shifter itself.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 02-13-2008, 02:45 PM   #5
krue
Designated A-hole!
krue's Avatar
Your engine must have a lot more torque than mine, 'cuz I have the above (put a 200-4r in it) and have no issues with it.
www.daveramsey.com
Old 02-13-2008, 04:47 PM   #6
FLEET72
FLEET72's Avatar
No, not a lot but it is noticeable. You can see the shifter move when under heavy load.
Oscar
'95 Jimmy 4X4
Old 02-13-2008, 08:10 PM   #7
hilljob26
hilljob26's Avatar
the 4x4 bracket is different,its alot smaller then the 2wd.although that setup thats in the pioc above looks to be the way to go
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-13-2008, 09:36 PM   #8
mrein3
mrein3's Avatar
I don't know if this helps but I switched from a manual (3-speed column) to a th350 in my K10 4x4. I bought the tranny, adapter, and t-case out of a 1972 Blazer. While I was showing the guy how to get the tranny off the engine I talked him out of the shift linkage and bracket on the frame. On my truck frame I had to drill two holes for the bracket on the frame. It has worked fine since I installed it in December of 2001.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-13-2008, 11:08 PM   #9
Dads 68 GMC
thanks for all the help guys, anyone have one of those little brackets that bolt on the frame? I would like to go that way.
Old 02-13-2008, 11:41 PM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here are all the pieces on a 2x4
sneakysnake is offline   Reply With Quote
Old 02-13-2008, 11:42 PM   #11
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Hey Dads 68 GMC,
Check with either board members teeitup or billsbowtie. Seems one of them had a large assortment of parts in a recent thread and I remember seeing that frame bracket.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 02-14-2008, 05:27 AM   #12
krue
Designated A-hole!
krue's Avatar
Your best bet will be to post a WTB thread on the parts board, please don't buy/sell anywhere else.
BTW here's a pic of what's on my Blazer so you'll know what to look for.
www.daveramsey.com
