![]() Join Date: Apr 2004
rear blazer seat pictures needed.
Anyone have pictures of their rear seat mounting brackets? I'm trying to determine if the rear seat that was in my blazer was stock. I'm going to sell it and install a removable seat from a suburban.
I know I could just post a picture of it, but I won't be able to take any until this weekend.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: rear blazer seat pictures needed.
Not the best pictures, but a general idea. Hope it helps.
My seat must be from the next body style. Thanks for the pictures.
SKINNY TIRES RULE!
The seats had either two or for brackets in the back. If they only had two, the belts were bolted directly to the floor in the middle two mounting points.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
any idea what drives this? mine only has the two outside brackets...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
SKINNY TIRES RULE!
I haven't figured that out yet. My guess is may 72 has the only outside brackets and the other years have all 4?
Mine Is A 72 And Only Has Two Outer Brackets
Hey Hot Rod If You Are Installing A Rear Seat Out Of A 90's Suburban I Put One In A 1993 Burb That Didnt Have One From Factory And It Was Surprisingly Easy 4 Chunks Of 2"x3" Square Tube Stock Notched Out Section On The 2" Side Drilled Hole On The Three Inch Side Slid In A 1/2 Or 3/4 Inch Bolt Welded All Up Located Floor Mounts From Seat Marked Cut And Welded In New Pockets On The Bottom Side (tacked On Top To Just Hold Until I Could Get Them Good From The Bottom )and Used Factory Chrome Trim Plates And You Couldnt Even Tell It Never Had A Seat |
I cut my brackets out of a suburban. Should be an easy install. just need to measure a million times before I hack up my floor.
urban fourwheelin
Mine is a 72 and it has all four brackets, but they are spaced different than the one pictured.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
Here is what I have. Not good pictures, but it was the best I could do with the space I had.
That's the correct seat for the 69-72 blazers.
Why no ashtrays? Did they make then with out?
#13 |
SKINNY TIRES RULE!
Looks like the arm rest were recovered. I bet if you pull off the covers, you'll find signs of the hole from the ashtrays.
#14 |
What is this seat worth?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht Last edited by hotrodhomi; 02-15-2008 at 02:04 AM. |
#15 |
SKINNY TIRES RULE!
$40-50? It isn't the original cover and the color isn't the most desirable. Also, someone had modified the front brackets with tabs to hold the seat down rather than using the original clamps.
#16 |
That's what I was thinking, they were covered up when the new covering was done.
I have a set of 'stock' front legs if you wanna try to sell it that way. (as stock) |
#17 | |
#18 |
It sold in less than 24 hours. Had 7 calls. Must be rare in these parts.
#19 |
SKINNY TIRES RULE!
What are you going to do about a back seat?
