magnaflow with leaf springs Question
I am looking to put new exhaust on my truck and I like magnaflow but I looked at their website and it says (coil rears). I did a search and found some good stuff but no one with leaf spring rear. I don't see how it could be that different and I am not opposed to doing some BFH adjustments. My concern is that it will be way off or be a big pain and I would be better just doing custom exhaust. Pictures would be great.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
Re: magnaflow with leaf springs Question
I'm also curious about this...
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
67-72 Addict!
I just did a search for the new Thrush system that came out recently for our trucks but it's also for coil spring only according their site.
http://www.thrushexhaust.com/pdf/thrush.pdf
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Fabricate till you "puke"
Well, your leaf spring truck is wide open inside the rails, whereas the coil truck has to route the pipes around/over the trailing arms. I dont think you will have any trouble hanging a ex system for a coil truck on your leaf sprung truck(it just might have a few bends that you wouldnt need to have) for your app.The shock mounts are a little different, & you may need to "play with " the hangers. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I think the problem is more where the pipe exit the out the sides just past the fenders behind the rear tire. I think there would be interference how the pipe exits.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
#6 | |
67-72 Addict!
I have no idea on price. I found it in the April 2008 edition of Classic Trucks on page 24 at the bottom. 66-72 GM trucks is part #89027. Complete 2.5" slip fit, bolt on with all pipes, muffs and hardware.
Yea, it might be an issue around the rear spring hangers.....I like to run em straight out the butt end(sounds better IMO). crazyL
I think I will throw caution to the wind and buy the kit. I guess worst case I will have to fab the rear exits to go straight out. That is the way mine is now and I prefer it straight out the back under the bumper. Thanks for the help guys.
