Old 02-14-2008, 04:32 AM   #1
Blue'72
Skinned knuckles
Blue'72's Avatar
Red face I can't find these zert fittings
My clutch has been chattering for some time now when I start to take off and I need to grease it, but I can't find the zert fittings. Anyone?
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 02-14-2008, 05:22 AM   #2
cdowns
cdowns's Avatar
Re: I can't find these zert fittings
most auto parts stores carry them
Old 02-14-2008, 05:50 AM   #3
Blue'72
Skinned knuckles
Blue'72's Avatar
Cool, thanks!
'07 Sebring
Old 02-14-2008, 07:44 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
ask them for a zerk though, they may laugh at a zert.
Old 02-15-2008, 12:06 AM   #5
Blue'72
Skinned knuckles
Blue'72's Avatar
Oh, my bad.
Actually, this post stemmed from a conversation I had with a moron here at work who doesn't understand the concept of friction. Not exactly this scenerio, but it made me think about greasing the clutch and or brakes..
Now back to reality..
'07 Sebring
Old 02-14-2008, 09:24 AM   #6
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Surprisingly, Lowes has a large selection of zerks. 90,45 and straight
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 02-14-2008, 09:27 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Maybe I'm missing somthing... I didn't know clutches had a zerk fitting. Or is someone pulling my leg??
The ones I've had that chattered were alway contaminated somehow. The flywheel/clutch/clutch plate was burned, cracked, oil impregnated, etc...
68gmsee is offline   Reply With Quote
Old 02-14-2008, 10:32 AM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'm with you. I understand a chattering clutch, but there ain't no grease that's gonna do you any good. In fact, last time I checked, getting grease on a clutch was pretty much the end of that clutch.
Now, if it's the clutch Z-arm that needs grease, that's different. But I don't think that would be a source of clutch chatter.
Reminds me of my first car. The throwout bearing was going bad, fast. But, here it was time to go deer hunting on New Years Day, 1965. As we got ready to leave for home, it became obvious it was gonna be difficult. An older man suggested putting "something" between the arm of the clutch release bearing and the rod that actuated it when you pushed the clutch. Made sense to a couple of 17-yr old boys. So, we found a fitting for a gas (natural/propane), a bushing if you will, and inserted it between points A and B. Pushing on the clutch pedal made seemed to be better the first couple of times......until the arm broke off of the fulcrum inside the bell housing. Now, I was 100 miles from home, and no clutch action. Start it in gear, and shift it "carefully". I was almost home when I ran into a couple more buddies, who pulled my car to their house...still 15 miles from mine.
Next day, Dad and I went to get my car. It was raining....a lot. Where my car was parked, there was mud....a lot. Starting the car in a cold rain was not my best trait, especially with no clutch. Jacked up the right rear wheel, put it in gear and cranked it over. It started and Dad gave me a shove, off of the jack. Up the driveway/road I went until I got to the end of it, which was uphill, and onto a state highway and I couldn't see anything over the front of the hood, which was pointing up into the air as I approached the highway. I never slowed down as I hit the pavement. It's a good thing nobody was coming. I could have hit someone head-on, or been rear-ended.
Anyway, I took it to a guy who lived nearby and did "shade tree" mechanic work. He pulled the tranny, and the bell housing, drilled out the broken parts and re-installed the fork and fulcrum with new hardware. Five weeks later, I got rear-ended, and knocked into another car, and my car was essentially totaled.
Don't grease the clutch, though.
Member Nr. 2770
Old 02-14-2008, 10:54 AM   #9
68gmsee
Active Member
68gmsee's Avatar
What a bummer... I bet your dad wasn't too happy about you totalling it after all that work to get you home.
Old 02-15-2008, 12:28 AM   #10
chrislehr
Engine n00b
chrislehr's Avatar
wth is a zerk? pics?
chrislehr is offline   Reply With Quote
Old 02-15-2008, 12:40 AM   #11
ETsC10
Hand Crafted C-10
ETsC10's Avatar
zerk.
ETsC10 is offline   Reply With Quote
Old 02-15-2008, 02:50 AM   #12
chrislehr
Engine n00b
chrislehr's Avatar
Originally Posted by ETsC10 View Post
zerk.
Oh.
Always just called em grease fittings.
How many does my 1970 have? I need a new gun!
Old 02-15-2008, 03:16 AM   #13
tcb-1
Nothing to see here.....
tcb-1's Avatar
Originally Posted by chrislehr View Post
Oh.
approximately 7-8 a side for the front suspension (1/2 ton 2wd). just greased all mine up a few days ago.......
upper control arm: 2
lower control arm: 2
upper ball joint: 1
lower ball joint: 1
tie rod: 1
pitman arm: 1
idler arm: I believe 2
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-15-2008, 03:10 AM   #14
Blue'72
Skinned knuckles
Blue'72's Avatar
The top and bottom ball joints on the a-arms as well as a couple on the steering linkage. Prolly more, but I can't think of them right now.
But none for the clutch..
'07 Sebring
Old 02-15-2008, 06:11 AM   #15
retodd7711
retodd7711's Avatar
Don't forget the universal joints.
And the muffler bearing
She can't cook
So forget her.
My old farm truck
Old 02-15-2008, 06:43 AM   #16
Longhorn Man
don't forget the slip shaft on the 2 pce drive shaft, and the inner tire rod ends too.
Old 02-15-2008, 09:25 AM   #17
Shane
Shane's Avatar
why do you need to grease the clutch? or am i missing something?
Shane is offline   Reply With Quote
Old 02-15-2008, 10:06 AM   #18
Longhorn Man
in big trucks, you have to lube the throw out bearing, but not light dutys.
