Removing rear fenders and bed?
Hello everyone, Im new to the forum and also new to doing any type of restoring. That being said, I am having a little bit of an issue with removing my rear fenders and bed. How do I stop the bolts on the top-side from moving when I am using my (if I remember right) 9/16 wrench on the bottom side? The bolt top is solid with nothing to grab onto?
Any help would be greatly appreciated. Thanks-J |
Re: Removing rear fenders and bed?
I put a tack weld on the head to the floor and then took the nut off. Then take a hammer and breack the weld.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
Prestige Worldwide
![]() Join Date: Feb 2001
You could take a cut-off wheel and cut slots in the bolt head so you can use a screwdriver. I have heard of guys putting a tack weld on the bolt head to hold them. I had to just take my cut-off wheel and cut them off on the underside of the bed, I tryed to use penetrating oil but after 35 or so years they were being stubborn. Just have to be careful with that and be sure not to mess up your sheetmetal.
Aha...learn something new everyday! I however dont have a welder yet. Thats my next expense. Thanks for the idea though. Recommend a decent affordable welder? Lincoln maybe?
Thanks again. |
Thanks. I think I'll try the cut-off wheel first and if that doesnt work well. I'll wait for the welder. Thanks again for the ideas for the newb here. Its always been a dream of mine to do something like this (however not in a single-car garage) but now that I own a home Its all I have been thinking about.
take care! |
Skinned knuckles
Welcome jaredstillwell! You'll find so much knowledge here that you're bound to get in trouble somehow!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) ![]() '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
the bolts holding the bed and fenders on are so cheap and common that i just do it quick and easy by grinding the heads off completely and usually replace with stainless ones on reassembly
LAIDOUT
Mine were very stubborn so I used the flame wrench to get them off!
