Driving But So So Brakes??
Well It Is On The Road
But I Got Brake Issues How Can One Effectively Bleed The Brakes New Caliper/new Pads/new Master Cylinder Bench Bled Master Cylinder/gravity Bled Both Calipers/then Pumped Up And Bled Both Side And Still Run Out Of Pedal And Cannot Lock Up The Front End (havent Gone Thru The Rears Yet Maybe This Weekend) What Is A Speed Bleeder And How Does It Work Somebody Else In Another Thread Had Mentioned Them And I Have Never Heard Of Them Any Input Would Be Sweet. I M Sure I Still Have Air In The System But Do I Keep Just Bleeding Them Until I Get Good Pedal?? Last edited by DANTES JIMMY; 02-14-2008 at 07:23 AM. |
Re: Driving But So So Brakes??
My experiance is with speed bleeders is that you just crack it open a little and push on the pedal, ball and spring take care of opening and closing like a valve. Not as messy, if you hook up a hose to it and route it to a can. Usually if you see bubbles in the can, you've got the air out. You still have to work from the farthest to the closest. As soon as you let go of the pedal the spring pushes the ball back against the seat.
Keep an eye on the level of the master cylinder, don't ask me how I know ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
urban fourwheelin
I have a few questions....
1) Did you have the rear drums off? 2) If, so did you check the wheel cylinders for seepage or leaks? 3) Are the rear brakes adjusted properly? 4) Did you bleed all four corners? Honestly, In my experience blazers don't have that great of a pedal. I can't lock mine up either. but, If the rear brakes aren't adjusted correctly it can cause a bad pedal. So can a seeping or leaking wheel cylinder as it can pull air back in when you let off the brakes. IMHO the best way to bleed a blazer out, is to start with either the right or left side of the truck. Lets say the right, open the right rear and the right front and just let it drip for 20 minutes, close them. Then do the same on the left side for 20 minutes. I've actually gotten a good pedal this way with only myself, but wouldn't recommend it. Then with someone inside pumping the pedal with nice, steady, even, and slow strokes, have them pump till firm, hold it, than open the bleeder screw. Some air might come out or not. Repeat at each corner until a solid solid stream comes out, three or four times in a row with no bubbles. Bleed in the standard RR, LR, RF, LF pattern. if You have any questions feel free to pm me. I work at a popular west coast tire dealer famous for free beef as a brake and suspension "specialist". Another thing to think about is a 3/4 ton Master and booster swap. As the M/c has a bigger bore and the booster is a dual diaphragm....
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
Good recomendation on the3/4 ton M/C, that should lock up your wheels. I also thought of another problem you mite have. A rubber hose could be ballooning on you, thing is, you don't see it. When you hit your pedal, the pressure pushes the outside wall of the rubber hose out, then you don't have enuff pressure for the brakes
Something is wrong if your running out of pedal, and it sounds like air
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-14-2008 at 10:47 PM. |
Post Whore
![]() Join Date: Feb 2000
In the faq section I put up a post on a power bleeder that I built for very little money - sure makes bleeding brakes quick. Check it out.
I did the 3/4 master swap and my power brakes stop very effectively and have great pedal feel.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Ok Thats Great
Ill Redo The Rears This Weekend And Try All This Stuff If All Else Fails Ill Switch To A 3/4 Mc What Model Should I Use For Cross Reference 4x4, Pwr Brake,k20,dana 44 Or Should I Just Make Sure It Is For Proper Year For Fittings And Booster Mating Ps I Inspected The Rubber Hoses For Any Sign Of Wear But It Is Still Possible Would I Be Able To See Or Feel The Swell If They Are Bad?? |
You'll only be able to see/feel it as someone else is pushing on the brake pedal. Any 3/4, 1 ton truck M/C will work from our years, don't know on the '73 and up, but possible
Red72blazer is right! I meant to include the booster as well...J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-15-2008 at 05:02 AM. |
urban fourwheelin
you have to use the booster as well.
Keepin it runnin!
In the 20+ years I've owned my K5 I never had super brakes until I replaced all wheel cylinders, hoses & shoes at the same time. The method I was taught is similiar. I usually gravity drain the old fluid out fully first. Then I have the "assistant" only push the pedal down once and holds it there says "down", then I'd open the bleed valve until the fluid just about stops, shut the bleed valve, then I tell the assistant "up". they reply and tell me when "up" (and off the pedal). The process is repeated until all air is out. Usually 1 full reservor full.
Signs to look for that mean problem components... If as you bleed if you are getting an excessive amount of air then its possible that the master or wheel cyl are bad (even new can be bad). My experience is that if air bubbles comes back up into the master cyl then the Master cyl is bad. If no bubbles in the master cyl, but air at the wheel cyl=bad wheel cyl. I like the idea about using the 3/4 ton M/C. Next time mine goes...I'll be plugging one of them in! Frank
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
![]() Join Date: Dec 2002
When I got my 71 blazer almost 30 yrs ago it would lock all wheels up. 16yr old locking up the 44's in the high school parking lot just to hear the sound. Now both my 70 and 71 have good brakes but they won't lock them up. My guess is booster. Since the wife and kids want to ride them I am going 3/4 ton swap
Never heard of the gravity idea, but I will keep it in mind next time, Thanks
Im Going To Borrow A Vaccum Pump From A Buddy
And Give It A Crack And See How That Works He Swears By It Will Post Results |
#13 |
#/4 ton booster is the only way. It is simply a difference in single diaphram and dual. You will tap the peddle and lock them up. But in order to bleed brakes, especially with a new MC you must bleed the rears!! Start with the tire farthest from the MC and work your way closest (ie RR, LR, RF, then LF) then you'll have as good as you're going to get. The 3/4 booster and MC is about as cheap as just the booster?
#14 |
![]() Join Date: Nov 2007
I have the same deal with my brakes. Can't lock them up. I thought it was becuase I just installed a new motor with a big cam so I got a vacuum booster from summit. It didn't make much of a difference. I like the idea of going to 3/4 ton. Has anyone posted a tech tip on how to do this? Is it essentially replacing the booster and MC, bleeding and that's it? Now with the new engine the truck is fast, but not being able to stop is a little scary. How much do you think a shop would charge to do the swap?
#15 |
I bought mine from Frank Picmup on the left coast for 50 or 60, but haven't installed yet. Looks like a direct bolt up, but there may be issues with the brake lines, I think they have a different orientation. Simple fix would be to bend new line to fit correct location. I could be wrong on the brake lines, I haven't installed mine yet.
Try to buy one complete, including the linkage to the pedal. May be something different there aswell...J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-17-2008 at 03:30 AM. |
#16 |
Bolts up if you get one for a 72 3/4 ton, but you have to reroute the brake lines. The front line becomes the rear and visa versa, or buy new lines from in line tube for about $20-30. I did it and I'll never own another 4X4 without that upgrade.
#17 | |
Keepin it runnin!
Frank
#18 |
Well I Just Vaccum Pumped All Of Em Just Like Everybody Says And Then We Got A Pile Of Ice And Snow Salt Monster Is Lurking Every Where
Cant Test Drive Yet But If They Arent Better I Will Swap To 3/4 Ton Immediatly Not Being Able To Lock Em Up Just Sucks My Little Guy Will Not Be Able To Ride In It Until I Have The Most Braking I Can |
#19 |
Keepin it runnin!
I agree 100%. Tell me when your sitting, does the pedal "feel" rock hard? Because my 70 K5 with the current drums (25+ years old) and new cylinders, hoses & shoes is like a rock sitting, and will lock all 4 up if I hit it hard at about 45mph. Thats my test speed.
Frank
#20 |
Dante, any update on the brakes? I'm in the same boat
#21 |
Nope Still Bleeding
I Did Again Last Night And They Are Much Better But First Pump Can Go To Floor Second Pump Actually Feels Pretty Good If I Could Duplicate It On The First Pump I Would Be Tickled Please Please Let Me Know How Well The 3/4 Ton Stuff Works How Much Was The Booster And M/c From Napa?? |
#22 |
booster and mc from napa was $173. core is $33. It will take a week or so to get them though. I'll let you know how they work out.
#23 | |
#24 | |
Keepin it runnin!
Frank
#25 |
I'm doing the 3/4 ton swap booster and master cylinder. I am having a tough time finding the short brake lines from the proportioning valve to the mc. Any advice? Do I just get stock 3/4 lines from inline tube? My understanding is that the lines are reversed from the half ton? Help! this is all I have left to get my Blazer on the road.
