Old 02-14-2008, 10:38 AM   #1
thebabybrahma
Thumbs up bed liner
Anyon ever had a carpetted bed liner made or use a Bedrug? my little truck has a rolled on bedliner and it needs to be covered up a bit for a more finished look. i will try to attach picture of what i am working with. other ideas???
thebabybrahma is offline   Reply With Quote
Old 02-14-2008, 11:17 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: bed liner
Can you recoat it? I think that would be the best thing to do. I had a rug on my old Toyota pickup because I used to throw firewood and crap on it but it looked terrible after a couple of hot summers and a few rain showers. I've seen some trucks with outdoor type carpeting, but again it will start to look bad fairly rapidly. You will need to glue it on or the wind will whip it around. Neither type will dress up your truck for very long.
68gmsee is offline   Reply With Quote
Old 02-14-2008, 12:49 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: bed liner
I made my own panels and covered with marine grade carpet. My truck is garage kept so fading and wear are not an issue.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-14-2008, 06:42 PM   #4
thebabybrahma
Re: bed liner
just what i am looking for. where did you get the carpet? how did you fasten the panels to the truck after you covered them?
Old 02-14-2008, 09:14 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Re: bed liner
I found this at Lowes but any boat carpet will work. It's waterproof with UV inhibitors. It's rubber backed. I used 3M Dual lock tape, part #SJ 3560 to fasten to the truck.
Jim
Old 02-14-2008, 09:17 PM   #6
billdo
billdo's Avatar
Re: bed liner
the keg is sick i was gonna run two one for air the other for fuel but they arnt rated for enough pressure so i scraped the idea
billdo is offline   Reply With Quote
Old 02-15-2008, 08:16 AM   #7
thebabybrahma
Re: bed liner
70C10, could you send me some more pics of the bed of your truck so i can get a more detail look at the edges and up the sides near the rails? send to circlebcattle@embarqmail.com thanks
