floor conversion
well i took the 3 off the tree and put it on the floor. i bought a Mr. Gasket kit off ebay for 30 bux shipped. it got here today, and i pulled my old tranny up on the tail gate, it was already out of the truck. i mocked up how the floor shifter should work.
then looking around under my truck i found a few pop-rivitz in my floor board about where my future hole was going to be. so i tore the old carpet out and, low and behold, someone had beat me to the punch. as of now the shifter is in, and awaiting final adjustment. the knob hits the dash going into reverse, but not 2nd. and its no where near the seat in 1st or 3rd. so i'll crawl under the truck again and pivot the shifter back a little more. also the pre-existing hole needs to be a little bigger. All in all, the kit went in pretty easily. this is considering i didnt even know there was such a kit 2 weeks ago.
1976 chevy short box I6 250 3 on the tree..... $350 3 on the tree to 3 on the floor swap.............. $30 power steering swap................................... $100 Building a screamin I6 ................................. $500 Finally having the truck you always wanted... Priceless! |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: floor conversion
Good deal!!! HOWEVER...
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
86 C10
^^^what he said!!!!!!!!!!!!!!!!!
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
i used to have a 3 speed hurst shifter in my 72 that was cool but the seat used to make the shift into third a little difficult
I used it as an excuse to put in buckets
bmx, I was reading your thread, I have a 73 that has an I6 that orignally had a 3 on tree and has been converted to a truck 4 speed (granny) on the floor. saw on your byline that you converted to power steering as I have also (best thing I've done so far, what a difference). what did you do to make it a screamin I6? and also what are you going to do with the steering column and the old shifter nub sticking out? thanks bob
#6 | |
half of my list is future plans, IE the power steering and the screamin i6. i will be getting power steering soon for sure. and the screamin i6 will be a rebuilt 250. i have a spare 250 i will be working on. i found a grind i like from comp cams that will be going in. pretty much all the other internals will be stock or close to. mate that with a 6=8 intake, 4bbl carb, and some long tube headers, should be a pretty fun little motor. also the next plan of action for the truck is a new clutch and new disc breaks. i could get mine turned, but have been looking to see what else is out there. kinda spendy for new rotors, but i would like to be able to stop.
No No
Good deal. You just need to make sure and lubricate your linkage and check for wear about every oil change. Ive had the Mr gasket and cheap Hurst shifters before and they wear out kinda quick. I have a Factory hurst setup now from a 69 camaro. I cut the shifter and grafted one of the cheap Hurst arms to it so It clears the bench seat and look good. It's much better but I'd rather have a coulmb shift back. I miss shifting on the tree. My fiancie thinks I marrying her just so I can drive her Appolo so I dont have coulmb shift withdrawl. Might have somthing to do with it.....
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
yeller
Column shift trucks are cool! You took away some of it's unique-ness by comverting it to a floor shifter IMO. I'll never forget the funny looks I got from other motorist when rowing thru the gears on the column in my old 78 250/3 speed. However, it's your truck, do what you like and enjoy it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
hey guys i need a little help. (go figure)
i got the floor swap done with the new tranny in. got the truck started and it ran and moved in gear just fine. the problem is no longer the tranny or the shifter. i started it up again after work in the driveway, and the cab filled with smoke. i checked it out and i fried the main power wire from the splitter on the fire wall all the way into the cab. i think it took a few wires with it as well. i went to schmuks to get some wire and connectors, but then thought it might be better just to go to the local pull-a-part and get another wiring harness. so i will do some research online, but i need to figure out what harness's will inter change with my truck. i think chevy pretty much made them universal for the 73-80 pickups, but want to double check before i go pulling one i dont need. my truck has all the basic options, no power windows or cruise control. its a 76 2wd m/t. what do you think. do i need to find another one from a 6 cylinder or can i get one from an auto with a 350. anything helps guys. oh btw, im pretty sure i just forgot to connect the ground to the firewall. i cant come up with any other explanation for why it did this.
#10 | |
It Is What It Is,,,,
Me too, only my first is a bit difficult. My 2nd to 3rd is smooth.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
The truck I just bought has a tore up column shifter, so I bought a Hurst Indy for $50 (new) and hope to get it installed when it gets here.
I was going to splurge on the Mastershift, but it was $275 for the shifter and install kit. I would hate to spend that much dough and find out my trans is in bad shape. Anyone have install tips and tricks for a column to floor? I found a few threads (like this one) but nobody lays out the steps. Is it just that easy?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#12 | |
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#13 | |
lucky knuckles
![]() Quote:
any pics of the power-steering swap? what pump did you use? i've got arm-strong steering and it's alright, but down the road i'd like to update it. i've got the 250 too. so far all i've done is put an electric fan in place of the mechanical one. huge difference. i'm hoping for headers in a few weeks, not sure about running duals or a single set-up. i was thinking about twin 44s but now i'm thinking i might just run it into one. (cash issue) you've got some good ideas, good luck with them. |
