Old 02-15-2008, 02:23 AM   #1
CG
BlahBlahBlah
Lowering springs pic...burb vs truck
I dont know if you burb guys knew they make heavier duty lowering springs for burbs and panels. It came up on the board the other day so I dug out my springs and I snapped a pic of the two different styles for everyone. Both are 4" lowering, one for truck and one for burb/panel.
Old 02-15-2008, 02:27 AM   #2
crews
It just doesn't matter
Re: Lowering springs pic...burb vs truck
Not to hi-jack, but where did you get the ones for the Burbs? Do you know if they offer different drops?
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 02-15-2008, 02:41 AM   #3
CG
BlahBlahBlah
I dont know if they make different drops. I got them from PICKMUP here on the board. You will have to ask him.
Old 02-15-2008, 02:43 AM   #4
Frizzle Fry
Frizzle Fry's Avatar
Good info CG. I've seen that they list them seperatley in some catalogs, but never saw the physical difference.
Frizzle Fry is offline   Reply With Quote
Old 02-15-2008, 04:26 AM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
thats got to be the rear springs, right? Makes sense, cause burbs and panels have alot more weight in the rear.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-15-2008, 04:32 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
How well would the Burb springs work on a truck??? Or would they?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-15-2008, 06:50 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is quite a bit huh? Thanks for showing this Mark... a LOT of us didn't know about this.
And Joe... welcome to the burb club!
Old 02-15-2008, 07:03 AM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I didn't know.I have the springs (4 in drop) on my panel.I haven't had weather/time to do the spindles yet.I am hoping for the stance to be what i want but had thought I may have to go to a 3 in spring.I also may do some light towing(small travel trailer) eventually and the heavier spring may be the ticket for that.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-15-2008, 09:12 AM   #9
70c10
67-72 Addict!
70c10's Avatar
Mark, can you place a tape measure down thru the coils and do a measurement comparison of height?. The thick one looks almost 1" shorter!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-15-2008, 09:14 AM   #10
1LoC10
Insert Title Here
1LoC10's Avatar
so if you put truck springs on a panel, it would be slammed
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-15-2008, 09:47 AM   #11
CG
BlahBlahBlah
Yeah its shorter but as you can see a lot more stout. Im guessing there isnt much give when you set the body down compared to the truck version.
Old 02-15-2008, 09:47 AM   #12
Boog
laying low
Boog's Avatar
I bet it would be bouncy, to say the least, due to the lighter spring and heavier weight of the burb.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-15-2008, 09:49 AM   #13
CG
BlahBlahBlah
I bet you get close to the same drop but a lot bouncier ride and any kind of load would probably get you down there.
Old 02-15-2008, 11:05 AM   #14
Tim Christian
Tim Christian's Avatar
I have 5in truck springs in the rear by McGaughys on this burb
Tim Christian is offline   Reply With Quote
Old 02-15-2008, 11:19 AM   #15
Boog
laying low
Boog's Avatar
I know you are bound to carry some weight in that burb. So are they any softer than the original springs?
Boog
primer is finer
Old 02-15-2008, 09:19 PM   #16
MrGoodpliers
MrGoodpliers's Avatar
I ordered 6" drop coils from ECE for my burb and when I let the jack down, there was about an inch between the rear and the frame. Sent 'em back and got airbags.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-15-2008, 09:44 PM   #17
suville
suville's Avatar
Tim, are you runnin a notch in the rear of the Burb ? How is the ride with the truck springs ? cant decide which way to go ,springs or bags now another choice on the springs. Maybe that is why Dave at ECE recommended 3.5 front and 5 rear cus the burb springs are shorter than the truck. Concerned about the effecte of almost 500 Ft lbs of torque from the Cad! Thanks! Steve
suville is offline   Reply With Quote
