Old 02-15-2008, 12:20 PM   #1
Wild83C10
Wild83C10's Avatar
Parts For Sale-headers-cam-engine
I have the following parts for sale. All engine parts are used and for a Small Block Chevy.
1. Trick Flow heads-SOLD
2. '74 350 2-bolt long block. It needs a rebuild.
BO
3. '74 355 4-bolt short block assembly. Original 4-bolt block, cast crank and rods, forged pistons. Will include all new bearings. Needs to be assembled. I can help with delivery if within a reasonable distance, just pay for gas.
Machine Shop work:
cleaned
honed
new cam bearings
polished crank
new bearings
new rings
$800 or BO
4. Comp Cams Hydraulic Flat Tappet Cam w/ lifters and springs. Springs are matched to the cam. P/N for the cam is 12-254-3.
Specs: .519 intake lift, .523 exhaust lift, 294 intake duration, 306 exhaust duration at tappet lift. 250, 256 at .050 lift. 110 lobe separation. I have original box and cam card.
$275 or BO, plus shipping
5. Cammotion Hydraulic Roller Cam w/springs, NO lifters. Custom ground cam, Grind Number: X2371-24410-10.
Specs: .580 intake lift, .592 exhaust lift (w/1.6 rockers), 239 intake duration, 247 exhaust duration @ .050 lift. 110 lobe separation. I have original box and cam card.
$275 or BO, Plus shipping
6. Summit 2" Drop Springs. SOLD
7. Hedman Headers. Long Tube Headers for 73-86 Chevy C10 w/SBC. They are in good condition, with black header paint. I painted them before I used them and baked the paint on. The paint looks ok and it has kept the headers in good condition. They have a 3" Flowmaster ball flange collector on the end. The ball flange doesn't require a gasket and works great. I also have an O2 bung in each header (running aftermarket EFI). They are 1-5/8" primaries, no dents or dings. HEDMAN P/N 69090
$60 or BO
Please ask any questions. If you buy multiple items I will make a deal.
Thanks,
Joe
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-15-2008, 12:27 PM   #2
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Parts For Sale
I couldnt finf the part # on the web site. are these alum or iron heads?
Trick Flow heads-195cc intake runners, 2.02 intake and 1.60 exhaust valves. Pushrod guide plates, 3/8" rocker arm studs. All original, no port work done. I have more info if you want, just ask. P/N: TFS-31400001. Currently installed are the springs for the Cammotion cam listed below. If you buy one of the cams with the heads I will install the springs for that cam otherwise I will install springs for your cam or original type springs.
$725 or BO plus shipping
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-15-2008, 01:03 PM   #3
jay6891
Car Knocker
jay6891's Avatar
Re: Parts For Sale
I found a part number of tfs-3040001 that matches his description. 62 cc chambers and aluminum construction. Summit has them listed a 1025.00. Sounds good--- pending how used.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 02-15-2008, 11:21 PM   #4
Wild83C10
Wild83C10's Avatar
Re: Parts For Sale
They are aluminum heads. I must have screwed up the P/N somehow. I will double check it when I get home. I'm pretty sure they are 64cc heads, not 62cc. I have the original documents that came with the heads and that has all of the correct information on it.
turbo=
Old 02-15-2008, 11:30 PM   #5
HavinSomeFun
Re: Parts For Sale
let me know. I am about to build my engine and this would be a nice addition
Old 02-16-2008, 12:21 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Re: Parts For Sale
I'd be interested in the heads if they weren't angle plug heads. My headers only work with straight plug heads
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-16-2008, 03:48 AM   #7
70rs/ss
70rs/ss's Avatar
Re: Parts For Sale
I guess third on the heads and maybe roller cam.
70rs/ss is offline   Reply With Quote
Old 02-16-2008, 03:52 AM   #8
70rs/ss
70rs/ss's Avatar
Re: Parts For Sale
I looked up the second number and it shows an LT1 head? If they are Lt heads they will only fit an LT1 or 4. LMK for sure what they are, picts etc.
Old 02-16-2008, 06:30 AM   #9
Wild83C10
Wild83C10's Avatar
Re: Parts For Sale
Ok just pulled out the documents I got with the heads and the correct P/N is TFS-30400001. They are 64cc heads not 62cc heads. Trick Flow now list this head as TFS-30400001-CNC. The heads are for a gen 1 small block chevy. I had them on the '74 350 listed above. I can take any pictures you want. They are in good condition.
I'm selling everything because I just bought a 383 rotating assembly and I am going with a bigger cam, heads and headers. I actually forgot to list the headers.
Let me know if you have anymore questions.
turbo=
Old 02-18-2008, 05:34 AM   #10
sandking
.....I am working on it.....
sandking's Avatar
Re: Parts For Sale
I may be interested in the heads and headers. How much shipped to 92882?
View my build thread HERE
sandking is offline   Reply With Quote
Old 02-18-2008, 07:53 AM   #11
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: Parts For Sale
6. Summit 2" Drop Springs. Used on '83 Chevy 1/2 ton. Will fit 73-86, maybe 67-72? Powder Coated Blue. P/N: SUM-G727
$50 or BO
PM Sent.............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 03-02-2008, 08:12 PM   #12
Wild83C10
Wild83C10's Avatar
Re: Parts For Sale
Heads are listed on ebay now:
http://cgi.ebay.com/ebaymotors/ws/eB...MESE:IT&ih=019
turbo=
Old 03-09-2008, 11:37 PM   #13
Wild83C10
Wild83C10's Avatar
Re: Parts For Sale
HEADS are SOLD
turbo=
Old 03-10-2008, 03:59 AM   #14
49m
49m's Avatar
Re: Parts For Sale
Id be interested in pics of the headers. Will they work on an 67-72 chevy truck. And would you take $60 shipped
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 03-10-2008, 04:15 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Parts For Sale
if rick bails on the springs... let me know the shipping... I am very interested
Old 03-19-2008, 02:33 AM   #16
Wild83C10
Wild83C10's Avatar
Re: Parts For Sale
Springs are sold. Thanks Longhorn!
turbo=
Old 03-19-2008, 04:02 AM   #17
64GMCHorsepower
Justified!
Re: Parts For Sale
shipping on the headers to 35806?
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 03-19-2008, 04:59 AM   #18
Longhorn Man
Re: Parts For Sale
nope... thank you.
The burb will be pimpin!
Old 03-19-2008, 07:01 AM   #19
Jerblazer72
Re: Parts For Sale
I will jump in line on the headers. Let us know where you are at on them. Shipping to 84037. Thanks.
Jerblazer72 is offline   Reply With Quote
Old 03-23-2008, 01:30 AM   #20
Longhorn Man
Re: Parts For Sale
Thanks for the springs!
