header choice
I have narrowed my header choice to hedman elite or ceramic coated hooker comps. I like the elite collector ball in socket joint. But not sure so I will let some of you voice your thoughts.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
yes, i do
Re: header choice
i would go with the hooker ceramic coated headers. they'll look nice longer and keep under hood temps down. not too sure about that whole ball and socket thing on exhaust
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Re: header choice
the ball and socket thing is awesome.....verry feiw prollems with leaks and easy to remove if need be....i beleive summit sells weld on adapters to convert any header to a ball and socket type connection
To The Levy
Re: header choice
Well, I Installed a big block, removed my hooker super comps, coated, that are only about a year used. make me an offer if interested. you didnt indicate weather you had small block or big block?
67-72 Addict!
Re: header choice
I like my Hooker Super Comps part #2808. Jet Hot sells the #2452 and their coating is better than Hookers factory coating.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Re: header choice
Both Hooker and Hedman are good headers, but the ball and socket thing isn't much better than the normal flange. Hooker has the best connector, a flat flange.
That said I bought the Hedman shortys and welded the ball and socket together....the best of all worlds!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
Love That '69
Re: header choice
I've got full length Dynomax ceramic coated headers on mine. They look great, keep the underhood temp down, and perform/sound great. No complaints here.
I AM CANADIAN!!!!! ![]() 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates Last edited by Classic69; 02-16-2008 at 01:28 AM. |
Re: header choice
Jim I love the super comps also but not sure if they are in the budget.
what is the main diff. between the comp and super comp?
Re: header choice
The ball socket is cool, but double nut the bolts, they will rattle loose and leak. I am not possitive I'd buy another set thoough. I think ceramic coated will be my next set, but not sure on a manufacturer.
Chevy nut
Re: header choice
I am using Hooker super comps. Havent had a problem with them ever...not even loose bolts.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" Last edited by caminokid; 02-16-2008 at 07:04 AM. |
#11 | |
Fabricate till you "puke"
Re: header choice
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: header choice
I have ceramic coated hedman elites and wasn't too impressed with the appearance. I don't have them installed yet so I can only comment on appearance. There was a lot of weld splatter on them. Not to refined, but then again, I am picky.
#13 | |
67-72 Addict!
Re: header choice
![]() I'm planning to ship mine to Airborne Coatings to have them recoated because I don't feel like trying out other brands.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 02-16-2008 at 05:13 AM. |
#14 |
Re: header choice
Jim that is what I think I will do. can anyone coment on the fitament of the 2452's? The jet-hot price is not much more than summits price.
#15 |
Re: header choice
I don't want to change your mind, but I have the Hedman Elites. I'm very pleased with them. I would've liked to have the ceramic coating, but the coating on my Hedmans have a 5 yr warranty. I also liked the price of the Hedmans also. they are well built, heavy duty headers. I did have to notch a couple places in the frame, but nothing too serious. I can get to all my plugs with a socket also.
You can't go wrong the Hooker Super Comps though. I've heard complaints about the regular Comp series, but nothing but good things about the Super Comps. here is a pic of my Hedman Elites. ![]()
#16 |
Java Mechanic
Re: header choice
As an alternative -- It's hard to beat Thorely and with the discount they are giving board members .. You can get a set for very little more than Hookers or headmans right now.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#17 |
Re: header choice
I like the thorleys but they are high with the coating.
What complaints have you heard about the reg comps? Super comps are to much money.
#18 |
Re: header choice
Well, the regular Comps are made with smaller tubing and use thinner 1/4" flanges. They're more prone to warp over time and start leaking around the exhaust ports. The biggest complaint I've heard is fitment. Some they theirs fit good with no problems others have said they had to cut, notch or modify the header tubes to fit. The regular Comps are just like any other budget header in the fact they fit trucks from 66-87. The Super Comps are more specific. One part # will fit 63-72's and another part # is for 73-87.
It's just like anything else out there, you get what you pay for. The Hedman Elites are less expensive because they are NOT ceramic coated. They have a thermal coating, meaning they have a high temp paint. It does have a 5 yr warranty though. They are a value with 3/8" flanges and the ball and socket collecters.
#19 | |
Re: header choice
#20 |
I wish I was a cowboy
![]() Join Date: Apr 2008
Re: header choice
I have the ball and socket thing on hedman's. If I could do it over, I'd definitely get elites or super comps - I agree that you get what you pay for, I've had to grind and bend and have leaks, and sheesh, sorry, I'm just disappointed with my exhaust story.
If you want them to last, leak-free, it's worth the extra $150-$200. I've had quality headers in the past and now I know what it's like to have cheapies. Then again, some people like to bang their head on the wall.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
#21 |
Re: header choice
Yep, headers aren't a good place to pinch pennies. I have used the cheapy $75 ones on some of my junk when I was a kid and didn't have the $$$, but now I spend the money on things I want to last, still not rich, but the good headers are $$$ and worth every penny when you don't have to replace gaskets all the time, or change your plugs without cussing and no burnt plug wires either. All of that luxery is worth the extra $100-200 to me.
#22 |
Re: header choice
The Thorleys are a nice set. Seat of the pants tells me there's more mid-range torque and no loss on the top end compared to the Hooker Competition headers I replaced.
I went with the nickel-chrome plated steel. I believe they were 369 or so delivered from Summit. They are turning a nice deep dark blued color now, I kinda like the look, and they don't hang as low. Edit: The build quality is fantastic; nice thick flanges and tubes. Another Edit: No clearance issues with a-arms or the clutch linkage either. Last edited by Jim_PA; 07-29-2008 at 09:23 PM. |
#23 |
Re: header choice
With Hedman, looks like Street or Elite, there is a 3/8" or so notch required on the passenger side where the #2 pipe crosses the lowest point of the frame. It looks like it just misses, but there's only about 1/16" clearance, and when the engine torques, it definitely touches. That'll ruin a good seal on the gaskets after a couple bangs up against the headers.
#24 | |
Re: header choice
68Stepbed: Where did you have to notch the frame? I have some Elites coming (used regular hedman's before, flange is warped on one, head warped on the other), and I want to notch before I bend tubes and warp flanges.
#25 |
Loving the Jimmster
Re: header choice
This is going to be my next purchase, thanks for the thread!!! is there any way we could get a few more pics of some differant brands??
thanks vance |
