02-15-2008, 03:05 PM | #1 |
Lemme show you something!!
Leaf Spring to Coil conversion
OK- here's the deal. I have a line on a fairly beat up 71 GMC 1/2 ton w/ leaf spring rear for cheap. I want to pirate the disc brakes off the front and put them on my '67. The question is: Can a person with tools, shop and average skill convert the leaf spring rear end to coil spring? Can I just pull out the axles and slap them in my current diff.? Should I just bag both ideas and keep a lookout for a 5-lug coil spring rear?
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
02-15-2008, 08:44 PM | #2 |
Re: Leaf Spring to Coil conversion
I have leaf springs and have been looking into a coil rear for a while now. It can be done by someone with an average skill level. You can buy new trailing arms, brackets, relocate shocks, panhard bar etc. and pretty much bolt/weld it in. I think the route I am going is buy a much more common coil spring rear end and trailing arm set up of a junk truck and swap it in as it sounds like you are wanting to know if you can do. I don't know about swapping axles but if they are the same rear end with the only difference being one is coil and one is leaf I don't see why not.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
02-15-2008, 09:58 PM | #3 |
Retired Air Force Veteran
Hey Guys,
I just completed a Leaf to Coils Conversion. I've got a 69 GMC and I'm an average Joe. It was not difficult. Biggest task, getting the brackets. I searched the board and alot of guys have frame parts. The panhard bracket. The (2) Cross-member to Trailing Arm Brackets. The Cross-member bracket for relocating the rear shocks. These were all factory riveted brackets - I used all grade 8 bolts. I was fortunate. I picked my Trailing Arms with Coils and Hardware up at a Swap Meet for a great price, again from a board member. I am using the GMC 6 lug axle and we cut the old brackets off and cleaned the axle off. Welded on NEW axle saddle brackets from Early Classic (ECE). Price was $29.00 pair plus shipping. I'm going with a Super Track Bar, again from ECE. Were doing a 5-6 inch drop using drop coils. I've got a SWB Step Side Wood Bed, So access is easy. Trust me, it was not difficult. PM me and I'll give you my number if you have questions. Good Luck Harry
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
02-15-2008, 10:03 PM | #4 |
I thought the 71-72 had a wider track width in the rear to match the front disks.
Hardest part of the swap would be getting the axle welded to the perchs in the right spot but if you take your time with an angle finder and tape measure it should be no problem |
02-15-2008, 11:27 PM | #5 | |
I can send you some pics if you like. good luck.
78 C10 LWB Super Cheyenne |
02-25-2014, 09:45 PM | #6 |
Can you post some pics please...
