Old 02-16-2008, 08:34 AM   #1
kxnomore
kxnomore's Avatar
How do you separate the two driveshafts????
Anybody know if there is an easy way to just pull out the rear half of a two piece driveshaft? I would like to leave the carrier bearing and front half in place.
I am swapping an Eaton with a 12 bolt, and the u-joint size is different, but it looks like I could just use the rear half of the 12 bolt driveshaft. The length appears to be exactly the same. Do these come apart pretty easy?
Thanks in advance...
kxnomore is offline   Reply With Quote
Old 02-16-2008, 08:45 AM   #2
oldsmobilekindofguy
Re: How do you separate the two driveshafts????
I would like to know this also because I have a similar problem,
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 02-16-2008, 10:05 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
unbolt from diff, and pull. If it doesn't slip right off, then something is way wrong.
Old 02-16-2008, 10:48 AM   #4
kxnomore
kxnomore's Avatar
Thanks Longhorn Man! But just my luck, they're stuck together something fierce. I'll eat a full bowl of wheaties in the morning and let you know what happens...
Old 02-16-2008, 10:50 AM   #5
Longhorn Man
you can try pumping grease in the zerk fitting, that'll obviously lube it, and it *should* push the two apart a bit too.
Old 02-16-2008, 10:51 AM   #6
long67
long67's Avatar
Mine has a bolt in the center of the middle yoke behind the u-joint. I had two press it apart.
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 02-16-2008, 11:37 AM   #7
Longhorn Man
if it's bolted, how does the slip shaft slip?
Old 02-16-2008, 12:02 PM   #8
Pont406
Mine is bolted also.
Pont406 is offline   Reply With Quote
Old 02-16-2008, 12:03 PM   #9
sdkid
The slip yoke may have a collar on the end of it. You may need to unscrew the collar. If it is a 4 speed trans the slip yoke will be between the shafts, if it from a 3 speed or an auto the slip will be in the tailshaft of the trans. If the slip is in the trans oneof the shafts will have the yoke bolted on the end of the shaft.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 02-16-2008, 12:14 PM   #10
Longhorn Man
woah... I ALWAYS forget about that... thanks!
On the longhorns, there is a slip yoke on the tranny AND a slip shaft on the 2 shafts. No bolt. I automaticly picture that set up.
Although... I didn't have to remove a bolt on the burb when I pulled the shaft out of it...
Old 02-17-2008, 10:40 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
1/2 one shaft 1/2 the other should get you on the road, but will no doubt give you a vibration. 2 piece driveshafts need to be balanced as an assembly.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-18-2008, 06:18 AM   #12
john
member #16
john's Avatar
Buy a conversion u joint.
john is offline   Reply With Quote
Old 02-18-2008, 09:05 AM   #13
kxnomore
kxnomore's Avatar
Thanks everybody for the advice and the saved potential vibration. I picked up a NAPA #348 Conversion U-joint and it worked great. My truck is back on the road and I'm loving the 12 bolt with a 3.08 rear end ratio!
Next week I'm swapping a non-original 3/4 ton 8 bolt front end with the 5 lug 1/2 ton set up from the same truck I got the 12 bolt out of. Hopefully you all will have some good tips for that one. Will it even work?
