custom dashes.....
anybody got any pics of custom dashes in 60-66 trucks? i want to do a custom dash and i have a idea but need some inspiration.
thanks, John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Re: custom dashes.....
Here's the 1959-60 Impala Dash that I have in my 60 chop....
1930 Olds 5 Window Coupe 1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350 1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!" 1966 Toronado 1971 Cutlass 1972 442 1978 Chevy 1/2 Long Fleetside 2001 Dodge 2500 |
1961 crewcab
here are some interior shots of the pink freak 65 chev truck.
I would really like the dash in the last picture!!
me too!
Here is my 1st attempt to do something cool...
Jason
resident wrencher
hey jason no spedo
![]() Join Date: Apr 2007
thats cool Jason!! send it my way
![]() ![]() Last edited by 283 Man; 02-17-2008 at 06:39 AM. |
![]() Join Date: Dec 2007
Here's the dash I put in my 65 from TPI, all electric, nice but I would have been happier with Auto Meter Guages
here's the link for more TPI http://www.tpigauges.com/ Dakota Digital http://www.dakotadigital.com/index.c...=cat/cat66.htm No Limit http://www.nolimit.net/products.asp?dept=1244 RBS http://rbsauto.com/dept.asp?d_id=172...&page=3&show=1 There's more if you look. I get most of my ideas from Classic Trucks http://www.classictrucks.com/index.html and other publications for older trucks and the good ole internet.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
![]() Join Date: Aug 2005
the impala dash is just plain bad ass!!! but it doesent fit the theme i decided to go with on my truck. the pink dash would actually be pretty cool if it was a different color. ill tell ya my idea... i decided to go with a kinda tank theme for my truck. i drew out some rough dash designs, ill scan them tomorrow and post them. thanks for the pics and ideas!!
John
here is my custom dash.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#13 |
Junior Member
awhite4557.....
what didn't you like about the tpi gauges???
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
#14 |
eventually ill be running a setup like Slow66, that pink freak truck is "interesting"...hooter girls are a nice touch though!
#15 |
#16 |
ok i decided what kind of dash im gonna build in my truck. now i know some of you arent gonna like my idea but i like it so im gonna do it. my only problem is am i going to be able to cut the old dash out and build the new one in without removing the windshield? i guess the seal really needs replaced but i dont know how to remove and reinstall my windshield. my windshield is perfect, no cracks or anything. layinrocker, did you cut your dash out or was it already like that? if you did it may i ask why? heres a pic of the dash im gonna build in mine. it is a big truck but i like it. im going to try and make it look as much like that as i can, except mines gonna have a center console added in(connected or integrated into the dash). i am no welder but i think i can manage. my question with that is how do i construct the dash? i was thinking build a frame with some small square tubing or something of the kind, and then weld some sheet metal from there. if i am wrong please correct me. sorry for all the questions, just trying to figure everything out. heres a pic of the dash im going for.
thanks, John
#17 |
1961 crewcab
you are right on on how to construct it.
just build a frame out of tubing, then lay the sheet metal over it , just spot weld it every 4-5 inches, and grind the welds smooth. Use a good sharp razor knife to cut the rubber on the outside of your winshield. cut the pillars and bottom until you can see the edge of the glass all the way around . then, I would suggest getting a friend to help, gently push the bottom of the winshield out, and pull it out of the rubber on the top. don't force it any where , it will crack. buy a new winshield rubber. then I suggest having a glass shop install it for you. If you are not in the middle of nowhere they can probably come to your place and install it there. |
#18 |
1961 crewcab
It would be easier to cut the dash out , and build the new dash with the winshield out.
if you do a decent job of cutting your old one out, you can probably sell it. I just saw one go on ebay for $70+ |
#19 |
fastruckin, the only thing I don't like about the TPI guages, is the odometer, it is hard to read without bending down to get straight with the speedometer, other than that, they are fine. The dash insert was very nice.
