02-16-2008, 08:36 PM | #1 |
Broken Down
Front Sway Bar ??
My 71 C10 didn't come with a front sway bar. Can I put one on and will it be worthwile to do so??? How hard is it to install?? Thanks.
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
02-16-2008, 09:17 PM | #2 |
Re: Front Sway Bar ??
the frame will need the sway bar brackets. Factory would be riveted on, so if you don't have holes, then you'll need to drill. Then the bushings mount to the brackets (one on each frame rail) and the ends go into bushings on the lower control arm. I don't remember off hand how the moutning is to the contorl arms, but they bolt so you'll likely need to drill holes tehre too.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
02-16-2008, 09:19 PM | #3 |
Still Just Havin Some Fun!
I believe all the holes are there. You will have to cut off two rivets and replace with bolts. There is a great thread with pictures in the FAQ section.
a green one with some stuff done to it.... |
02-16-2008, 10:12 PM | #4 |
Saving 1 truck at a time!
If your truck did not come with a swaybar (PO did not remove it) the holes will be there and you can just bolt in the new one. If you are going to drop your truck you will not even need the brackets. It is well worth the effort...it makes a big difference in body roll when turning.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
02-16-2008, 10:21 PM | #5 |
As mentioned, check out the FAQ on this one, it's great.
It's not a technically hard job but you might bust some knuckles getting those two rivets out; especially if you don't have the right tools to do it. Like I found out...:-) |
02-16-2008, 11:05 PM | #6 |
Absolutely, put the sway bar on. It's well worth the effort.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
02-17-2008, 12:55 AM | #7 |
67-72 Addict!
I had to grind the front two rivets out on my dad's truck and then it's just a bolt in deal.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-17-2008, 01:04 AM | #8 | |
Even with that, it's about a 30 minute to an hour install job. Is it worth it? YES!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-17-2008 at 01:05 AM. |
02-17-2008, 01:39 AM | #9 |
Tot Roddin'
I'm in the process of scrounging up the parts to install a sway bar on my truck. From what I've heard it will make your truck corner like never before. If you are planning on dropping the truck you have two options:
1. Lowered Mounting Brackets from ECE (Early Classic Enterprises) 2. Bolt the bushings directly to the frame (there's a FAQ someplace on the board, but the location has left me) Here's a link to one FAQ If you are planning to not lower your truck you will just need to pickup stock sway bar brackets off the board or another truck. There's actually two different sway bar's that can be used on your truck.... 1 1/4 and 1 1/16 bars. The larger dia. bar can be pulled from HD trucks 73-up if I'm not mistaken. The hardest part of the installation is supposed to be removing the two rivets from the frame. I'll post pics of my installation.... when I can get around to installing it.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-17-2008 at 01:43 AM. |
02-17-2008, 02:44 AM | #10 |
a zip gun works wonders on the rivets.....
it is a very good addition.. YES
02-17-2008, 06:34 AM | #11 |
Broken Down
Thanks everyone I will check out that FAQ!! Will have to hunt me up one now
02-18-2008, 02:24 AM | #12 |
Tot Roddin'
Here's one available on the parts board... it's a front sway bar with bushings. The only thing left to purchase would be the sway bar mounts... either stock, lowered, or directly to the frame.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
