![]() Join Date: Aug 2005
Radiator on eBay- What do you all think?
I found this one the other day. It looks pretty decent for the money and the guy has a pretty good feedback score. What do you think?
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI |
Chevy nut
Re: Radiator on eBay- What do you all think?
If it was a 4 row I would buy one.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Insert Title Here
id rather this one
http://cgi.ebay.com/ebaymotors/67-72...em350026356554
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Chevy nut
That looks better.
#5 | |
i actually bought the first one listed a while back. it is decent...i had to cut the lower hose outlet because it was angled wrong, but seems to work for now. Needed a cheap replacement to get back on the road. thats about all i have to say about it.
71 LWB c10- needs more work than I have money! ![]() ASE certified Ford Master Tech |
Two rows of Alum cools better than a 4 row copper. The two rows are big ovals, not little narrow ovals so they are way more efficient than the old school copper $200 is a steal if you don't I will, then I'll buy the shroud from the secong guy and add it to this rad!!
Summit sells these for slightly cheaper without auto trans provisions. Just grab a trans cooler from a junk yard and run them both.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
#9 | |
I thought the one summit sold was a one size fits all and you had to adapt it? I have bought two of them and they are pretty close to this price, but you need to make a mount for them as they are not the correct dimensions. I am going to buy one (not right now, but soon). |
SUM-380331 Summit Aluminum Racing Radiators
Radiator, Universal, Aluminum, Natural, 30.875 in. Wide, 19 in. High, 2.25 in. Thick, Each Today $179.95 SUM-380325 Summit Aluminum Racing Radiators Radiator, Universal, Aluminum, Natural, 25.75 in. Wide, 19 in. High, 2.25 in. Thick, Each Today $169.95 SUM-380328 Summit Aluminum Racing Radiators Radiator, Universal, Aluminum, Natural, 27.0625 in. Wide, 19.625 in. High, 2.25 in. Thick, Each Today $169.95 SUM-390124 Summit Stainless Steel Flexible Hoses Radiator Hose, Polished Stainless Steel Hose, Polished Aluminum Ends, 24 in. Length, Kit Today $77.95 SUM-380457 Summit Direct Fit Aluminum Radiators Radiator, Direct Fit, Aluminum, Natural, Chevy/ Pontiac/ Oldsmobile, Each Today $279.95 SUM-380456 Summit Direct Fit Aluminum Radiators Radiator, Direct Fit, Aluminum, Natural, Chevy/ Pontiac, Camaro/ Firebird, Each Today $289.95 SUM-380451 Summit Direct Fit Aluminum Radiators Radiator, Direct Fit, Aluminum, Natural, Ford/ Mercury, Each Today $279.95 SUM-380428 Summit Aluminum Racing Radiators Radiator, Universal, Aluminum, Natural, 27.375 in. Wide, 19 in. High, 2.25 in. Thick, Each Today $169.95 SUM-380324 Summit Aluminum Racing Radiators Radiator, Universal, Aluminum, Natural, 22 in. Wide, 19 in. High, 2.250 in. Thick, Each Today $169.95 SUM-380425 Summit Aluminum Racing Radiators Radiator, Universal, Aluminum, Natural, 25.75 in. Wide, 19 in. High, 2.25 in. Thick, Each Today $169.95 |
I just picked up an aluminum #369 radiator from a local radiator shop for $190, so check locally too.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
knuckle buster..
![]() Join Date: Oct 2007
this is a great deal, thats why i bought it last summer. does better than my old 4row and looks nicer too... the only problem was it was about 1/4" bigger than stock where it fits into the rubber supports on the bottom... but it sits flush, and after a little finessing
![]() go for it!!! |
#13 |
Thanks for the feedback guys. I'm about to swap out my 3spd manual for a 700r4 and you all know how our projects wind getting bigger and bigger? Well that's what's happening here. My stock radiator is ok, not great, so I figure since I gotta put a trans cooler in now I might as well look for a new radiator to boot. Next thing you know, you got a new truck...
#14 |
How much modification/fabrication are we talking here?
