WTB NOS or new.............
I need a POA valve. Let me know what you have........Thanks Jason
72 Cheyenne Super 80 Silverado Blazer 2wd |
Re: WTB NOS or new.............
ttt
Born Psycho
![]() Join Date: Feb 2001
there is an aftermarket version available. we had a 71 el camino at work last summer for a-c repairs and our head mechanic found one for it. it doesn't look the same as the original but works fine.check with your local parts stores, if i remember correctly it was a "four seasons" brand piece.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Thanks, I will keep checking all my options but,I have been told by O rileys that four seasons has discontinued theirs too.
Go to salvage yard and unbolt a few from 67 - 78 chevy/gmc cars or trucks. Probably cost you 0- $10 bucks. Most of the salvage guys don't even know what it is. Go to a real hardware store and buy a fitting where it screws in the end of the valve with female threads. This screwed fitting should have a small hole in middle (like 1/4") so you can blow air from an air compressor through it. If the valve opens up when you blow the air, it works. hook it up, vac your ac system, recharge and you're good to go.
#6 | |
Thats a good idea you have though! I would have never known how to test them to see if they were good.
These can even be adjusted to use the newer freons. I think an original will look way better than the modern day remakes. I think I have an NOS. Send me a email or private message.
#8 | |
![]() Join Date: Nov 2004
http://www.autoacforum.com/messagevi...&threadid=7567
1972 K-10 SWB Cheyenne Last edited by nyncompute; 02-21-2008 at 10:22 AM. |
STOLEN
![]() Join Date: Jun 2006
Did you call Old Air Products to see if they have any in stock? Pretty pricey.
In Search Of |
