Old 02-17-2008, 07:26 AM   #1
Richard Dobson
Spring Change
When going from a 250 6 cly to a 396 V8 do you need to change the front end springs?
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 02-17-2008, 07:44 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Spring Change
Probably not.....if you can live with an extra inch or inch & a half droop on the front end. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
