02-17-2008, 08:09 AM | #1 |
Wheel fitment- 15x10 with 4" backspacing?
Will a 15x10 with a 4" backspacnig fit under the rear with a 275-60-15? I found some sweet wheels in that size and WANT them. thanks guys
02-17-2008, 08:41 AM | #2 |
Re: Wheel fitment- 15x10 with 4" backspacing?
Pretty sure my 10's have 4" BS. I am running 275/60's & a 6" drop with no problems...
02-17-2008, 10:26 AM | #3 |
67-72 Addicted
Anyone know if 15X10 4 1/2" back spacing will fit? foung some nice ones on http://wheelvintiques.com/shopsite_s...ml/page35.html
02-17-2008, 11:24 AM | #4 |
i also have 15x10 with 275/60 tires and they fit with no rubing, and i think the only way a 4.5 bs will would fit is if you mini tub it to the frame, but im no expert!
02-17-2008, 11:44 AM | #5 |
Here is a 10 inch rim with 285's and 4.5 backspacing however, I have the early narrower 6 lug 12 bolt. About a 1/2 inch clearance from the bed. Hope this helps.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 02-17-2008 at 11:46 AM. |
02-18-2008, 10:18 AM | #6 |
67-72 Addicted
so a 15x10 4.5" back spacing wont fit right under my 71 1/2 ton fleet?
02-18-2008, 01:15 PM | #7 |
Here's mine.....15x10's with 4" bs and 275/60's
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
02-19-2008, 04:18 AM | #8 |
The Engine Whisperer
My 14" wide with 8.75" back spacing do not yet the frame
I did have to trim the bed floor and increase the tub size This is on a 698 rearend which is a little narrower than the 71 and up rears |
02-19-2008, 04:50 AM | #9 |
Here is mine 15x10 on the rear w/ 295-50-15 an 265 60 15 w/15x8 on the front
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
