go cyclones
Today is step one
Well me and my buddy are going to start tearing in to my truck today. I will try to take pictures, but you know how it is. Once that first bolt is out the race is one.
Post Whore
![]() Join Date: Feb 2000
Re: Today is step one
Yep, easy to forget the camera when you get into ripping them apart!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Dont Forget The Camera Just By A Disposable
I Really Wish I Would Have Good Luck And Remember It Is Better Than Any Day At Work No Matter How Frustrated You Get |
go cyclones
Yesterday we got the entire interior out and started on the front end. We probaly would have gotten a lot more done but while trying to find a engine hoist we stumbled into a local brewery and did the tour. Not to mention sampled some of his wares.
go cyclones
Sunday, we started out by removing the fenders and tore into the heater, engine, transmission, and transfer case. It was all pretty uneventful except for dropping the transfer case on the ground. What is the best way to get that thing out. While here is a couple more pictures. Al we have left is the rear bumber, brake lines rear running lights and wire. Hopefully we can get that done one night this week and get it to the body shop by ASAP.
Today I found out why some people take so long to finish a project. Once you start tearing into it, breaking thinks and looking at stuff at a different angle you start to see a ton of changes you want to make. Logically the time to make them is when it is apart. Hopefully I can contain myself and get through this with very few changes |
Nice place to start the rebuild, at the brewery
![]() I just bought a trans jack from Harbor Frt for a 100 bucks. Best money I ever spent, plus it will lift up to 800 lbs. ![]() Try to stay away from the 'mite as well syndrome' it adds years to the project, don't ask how I know...J. Great pics., thanks, keep them coming. I know it takes longer, but we enjoy looking at them
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-19-2008 at 12:55 PM. |
go cyclones
That jack stand would have been nice. I am going to make sure I get the frame from the body shop to put in all of the mechanicals before the body goes back on. It seems to make more sense. With that said, what is the best way of cleaning off the transmission, tranx case and engine to get ready for paint?
What are some of my options? |
That is a very difficult question to answer. The process is easy, the disposal of the crap is hard. A screw driver and putty knife will get rid of the bulk of the big stuff, can be swept up and put in the trash (my landfill doesn't mind!) Yours may. Then gunk and high pressure wash, make sure all holes are sealed up, but you end up with alot of brown water, and that is the stuff that is enviromentally difficult to get rid of
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-19-2008 at 08:15 PM. |
Its lookin' like a Blazer!
Oven cleaner goes a long way in getting the gunk including paint off your hard parts. Spray it on, let it sit for a bit then pressure wash, be sure not to inhale or get it in your eyes. Nice progress.
![]() Last edited by Big J; 02-19-2008 at 09:15 PM. |
Post Whore
Gotta agree, oven cleaner is good stuff. I also have found Castrol Super Clean is good once you get the heavy gunk off.
I have used oven cleaner in the past. Just keep away from parts you dont want to clean it will eat the paint. I you don't want the paint stripped don't use oven cleaner.
I did an engine block one time and the outside air spray a mist of oven cleaner on the hood of the truck not good for the paint of the truck that I did not want to strip.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
Your blazer looks to be in good condition. What are you plans? A complete frame-off restoration or just a frame-off body paint?
Good luck on the project... whatever it is. The things you notice taking it apart pale in comparison to the things you notice putting it back together. |
#13 |
Future TOTM Winner
I have that same trans jack from harbor freight. For the price I have been very impressed. The only trouble I had was one of the castors gave out. The problem was I had an NV4500 strapped to it at the time and it nearly topled over! I have since bolted on a heavier set of castors and everything is fine. Just a word of warning, I wouldn't want that transfercase to fall off and smash an arm or something.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#14 |
Thanks for the heads up, could you be alittle more specific. Did the axle come outa the wheel, or the caster became loose at the mount to the jack. Thank you
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#15 |
Where is the local brewery? Yuengling in Pottsville?
Nice Blazer too. I go trail riding near you in Trevorton. And racing at Line Mountain race track.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#16 |
The LuvShack Garage
Looking good so far, I will be doing something similar to this in the fall to "GQ"
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#17 |
go cyclones
We found a small craft brewery in williamsport call bavarian barbarian. Here is the link
http://www.bavarianbarbarian.com/ |
#18 |
Future TOTM Winner
I’m going from memory here but I believe there were two “plates” that held ball bearings in place. Whatever held these together (a rivet I think?) came apart, the wheel went one way and the bearings went rolling on the ground. In other words the mount was still bolted to the jack and the wheel still had its axel intact, but the swivel joint (up and down axis) that allowed the wheel to turn around totally busted.
#19 |
Did that used to be the Bull Frog Brewery??
#20 | |
#21 |
#22 |
go cyclones
No it is just a couple blocks from Bull Frog Brewery. Ive been in there a couple of times as well.
