Old 02-18-2008, 01:42 AM   #1
isotek
isotek's Avatar
Want to lower my 67 with springs and take out the rake???
Just want to know how low I can go before i have to start cutting on the frame. How low can I go with just springs. Thanks in advance for the help.
isotek is offline   Reply With Quote
Old 02-18-2008, 02:22 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Want to lower my 67 with spings and take out the rake???
isotek... ECE (Early Classic Enterprises) offers a 4/6 drop kit. I've seen people go as low as 5" in the front. Are you planning on running bags or a static drop? Check out the drop pics on ECE's website and that will help guide you for the look you are after.
Mainly you need to decide if you are going to run bags, or springs/spindles to lower your truck.
With bags you can basically bottom your tires out on your inner fender wells front/rear.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-18-2008, 05:12 AM   #3
isotek
isotek's Avatar
I would like to try the air ride but don't want to break the bank though. I'v seen some outstanding price tags on those setups. Would 3'' and 5'' springs level the truck out?? By the way thanks for your quick reply, And also this is the first truck I'v ever customized!!!
Old 02-18-2008, 07:21 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
isotek, there are different combinations that can level out the truck, but it depends on how low you want to go. Somewhere on the board there is a thread that has different ride heights of members trucks..... the location of the thread has escaped me. I will see if I can locate the thread. It will give you a little more insight into different ride heights, and will help you make your final decision.
-Nate
Old 02-18-2008, 07:23 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This thread will help you with wheel & tire fitment
-Nate
Old 02-24-2008, 07:38 AM   #6
Matt_ks
Matt_ks's Avatar
Re: Want to lower my 67 with springs and take out the rake???
a 3/5 will level out the truck, a 4/6 is a real nice ride hight u still have a good grd clearance, but if u get much lower u will need to notch the frame, its recommend that with the 4/6 that u install a notch. so it depends on what u want. Also LMC in Lenexa KS offers a nice drop kit. that is pretty cheap, but is still of very good quality.
Matt_ks is offline   Reply With Quote
