Old 02-18-2008, 04:17 AM   #1
squizzleboy
Door Wont Shut!
i need some help with the doors on my 63 chevy. the problem started when i took it home from the paint shop when i put in weatherstripping. im not sure what caused it or anything, so i need some help. since i put the new weatherstripping in the door wont shut all the way. it seems as if it shuts all the way in the front and pinches the stripping in fromt before the back closes. im not sure if im describing it well, so take a look at the pics and let me know whats wrong. thanks for the help
heres some side pics to show how much it is out...
here are some gap issues that i am having....
what i have tried to do was adjust because i thought that it might be hitting but i had no luck
any help would be greatly appreciated! thanks!
63 chevy
350 crate
th350
silverado seats
american autowire harness
squizzleboy is offline   Reply With Quote
Old 02-18-2008, 04:20 AM   #2
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: Door Wont Shut!
pics didn't attach properly. Click manage attachments below the reply, click browse, find your pic and attach.
ClassicAutoResto is offline   Reply With Quote
Old 02-18-2008, 04:22 AM   #3
squizzleboy
Re: Door Wont Shut!
thanks i fixed it and they should work now
63 chevy
350 crate
th350
silverado seats
Old 02-18-2008, 04:30 AM   #4
ClassicAutoResto
Rust Buster
Re: Door Wont Shut!
Might have to shim the bottom hinge mount, that would take care of the high front/low back. You can also try to adjust the strike plate inward to pull the door tighter in. Most new weatherstripping is tight until it shapes itself better to the door. I have had a few customers have the same problem, adjusted the striker, then have to readjust it back after a few weeks or so depending on the temps outside after it shapes itself.
Old 02-18-2008, 05:30 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Door Wont Shut!
It will take a while for the weather strip to conform to the door closed on it.
keep in mind that these were utilitarian by nature, and gm probably didn't send them out with perfect gaps from the factory.
Old 02-18-2008, 09:57 AM   #6
squizzleboy
Re: Door Wont Shut!
i figured that it would take a bit before the weatherstripping would fit to the doors, but it has been about 6 months since i put it in. but how do i adjust the striker? i took a look at it, but i didnt see any room for adjustment.
63 chevy
350 crate
th350
silverado seats
Old 02-22-2008, 12:44 PM   #7
squizzleboy
Re: Door Wont Shut!
and where do i shim?
63 chevy
350 crate
th350
silverado seats
Old 02-22-2008, 07:35 PM   #8
ClassicAutoResto
Rust Buster
Re: Door Wont Shut!
take the lower mount loose and shim behind the mount plate. The striker on the door frame needs to be loosened and tapped inward. Try just a little at a time until you get the fit you want. Jerry
Old 02-04-2009, 03:42 AM   #9
TimC63
TimC63's Avatar
Question Re: Door Wont Shut!
Hi squizzleboy,
Did you ever get your doors closed? I'm having the same issues on my '63 from the weatherstripping I purchased from Brothers. It looks like a quality product but I swear the engineering mold the manufacture uses is crap. I've had mine installed for about 3 mo. and it leaks worse than with no weatherstripping at all.
I'm willing to adjust my hinges if I have to, but it would suck if I had to end up adjusting other panels to match.
TimC63
TimC63 is offline   Reply With Quote
Old 02-04-2009, 04:32 AM   #10
bird7263
Urban Chop Shop
bird7263's Avatar
Re: Door Wont Shut!
I am having the same problem with my 66. My passenger door turned out ok, but the drivers is having the exact same problem as yours. I have the brothers seals as well. We have tried a few adjustments but no luck. My drivers will shut and seat right only if i slam i mean really slam the door.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods
1965 Chevy 1/2T Longbox, soon to be a slammed shop truck
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266
Semper Fi Marines
bird7263 is offline   Reply With Quote
Old 02-04-2009, 11:31 PM   #11
forestb
forestb's Avatar
Re: Door Wont Shut!
I have the same problem on the drivers side door on my 62 but I think it is caused by the window frame of the door being bent in but I'm not completely sure. If anyone has any ideas I would love to here them also.
forestb is offline   Reply With Quote
Old 02-04-2009, 11:44 PM   #12
joe231
joe231's Avatar
Re: Door Wont Shut!
a trick i've heard of to "break in" the weather striping is to remove the door strikes, hook a ratchet strap from door to door and put tension on the doors pulling against weather striping. let it set for several days, check the tension daily and ratchet the strap up a couple clicks to keep the doors under tension......
it is also a good idea to remove the strikes when adjusting the door alignment, for two reasons, one it saves the headache of a jammed door and it allows you to get the door alignment right with out the strikes interfering
CHEVY ONLY
Old 02-05-2009, 01:13 AM   #13
protrash64
Resistance is Futile
protrash64's Avatar
Re: Door Wont Shut!
I once saw on TV a guy adjust a door on an S10 by bending the frame a bit. It was to titen up the weatherstrip. I cant remember how he got leverage on it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
