I dun gradjiated collij!!!
Air ride setup
Well I switched over to a static drop on Screamin' a couple months back and figured I'd offer the board first crack at the Air ride components I pulled out. Almost all of it came from Suicide Doors except the switch box and check valve.
It was all installed (unless otherwise noted) and used very little. Some minor surface rust on the tank and plates, I rattle canned the plates to prevent them from rusting any further. 2 #2500 Firestone front bags 2 #2600 Firestone rears bags 4 1/2 FAST SMC valves (EDIT) 1 7 switch chrome box with valet key (Never installed) 1 5 gallon underbed tank 1 Viair 280c compressor 1 heavy duty check valve 1 145 psi pressure switch Front Suicide Doors plates and cups, cut down to 1 inch. all the fittings I used $450.00 plus shipping I want to sell this as a kit or bundle, not really looking to split it up. The parts weigh in @ 85 lbs and I have them boxed in 2 seperate boxes to avoid damage. My Zip code is 97051 so you can figure out the shipping price. Thanks for looking....Bill
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 02-18-2008 at 05:31 AM. |
Re: Air ride setup
More pics
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
Car Knocker
Re: Air ride setup
I'll take it if you decide to seperate. Don't want the valves... I was gonna use 1/2" and the wire look to be cut a little short to reuse on yours.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
Re: Air ride setup
pm sent, please put me 1st in line pending a couple of questions
Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
Re: Air ride setup
damm, typed the pm 1st,
Car Knocker
Re: Air ride setup
Don't sweat it. If you want it all then it is yours. I'm only interested it he will seperate.
Re: Air ride setup
My bad, they are 1/2 in valves bushed down to 3/8 to slow em down. As far as the wires, the plug comes off and the wires are held in by screw/lug terminals. They actually come with no wires attached. See pics
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 02-18-2008 at 05:43 AM. |
Re: Air ride setup
PM back at ya
Re: Air ride setup
Sold to IAFF2407 pending confirmation this will fit his 3/4 ton with coils.
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 02-18-2008 at 11:42 PM. |
Tot Roddin'
Re: Air ride setup
Sweet deal... good luck IAFF...!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-18-2008 at 07:08 AM. |
1970 Daily Driver
Re: Air ride setup
If it does not go through I would like to be put next in line. Thanks
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Re: Air ride setup
IAFF2407, here are the pics you requested showing how low my truck sat with the bags, this is without spindles or blocks with 275/60/15 tires front and rear. Let me know if you heard back from CPP and if this is what your looking for.
#13 |
Re: Air ride setup
Could you put me in line too please.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#14 |
Re: Air ride setup
I'm in Screamin_C10, I'm getting 50/50 answers on whether the system will work for the 3/4 Burb, but I can still use them on the Sierra if need be. PM sent
thx, Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban Last edited by IAFF2407; 02-20-2008 at 02:06 AM. |
#15 |
Re: Air ride setup
SOLD to IAFF2407
