Old 02-18-2008, 06:33 AM   #1
iliveintn
Question What did I do wrong when I reinstalled my gas tank?
When I go to the gas station and put the nozzle completely in the filler it'll run full blast for maybe 2 seconds then shut off. I'm guessing I have some sort of line pinched and the air isn't venting correctly but that was the first time I put a gas tank in a vehicle so i'm really not 100% sure. thanks for the help.
iliveintn is offline   Reply With Quote
Old 02-18-2008, 08:09 AM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: What did I do wrong when I reinstalled my gas tank?
You probably routed the main filler tube incorrectly and it’s now kinked. This doesn’t allow the gas to run down quick enough and it backs up towards the nozzle. Why did you have your tank out? Did you change any of the pieces or use everything that was pulled out originally?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-18-2008, 10:03 AM   #3
jojotonka
jojotonka's Avatar
Heck, maybe you just had a crap gas pump.. Try a different one first... That happened the other day filling up my wife's 2006 Durango. I had to have the pump pulled partially out and set on the slowest setting. Try the easy things first.
jojotonka is offline   Reply With Quote
Old 02-18-2008, 01:11 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Sometimes, it takes 2-3 times before it will stay on when I fill my truck. Then, I have to watch how much I've pumped because if I leave it to shut off automatically, I get gas down the side of my truck. Mine is completely stock. I think it is just a case of the new not mixing well with the old.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-19-2008, 12:10 AM   #5
Mint68
Mint68's Avatar
Mine does the same think. I just dont put it in all the way.
Mint68 is offline   Reply With Quote
Old 02-19-2008, 12:17 AM   #6
bouncytruck
SKINNY TIRES RULE!
That's what I found to be the key too, which is probably why it doesn't shut off when the tank is full.
bouncytruck 1972 K5
Old 02-19-2008, 01:03 AM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
Great advise!!! LOL
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-19-2008, 09:31 AM   #8
iliveintn
on the gas tank note, does anyone know if gas can eat through JB weld?
because apparently my tank is leaking again. I shouldve just lined where it is leaking with the $20 bill I spent on the gas that is now killing the grass at my parents backyard.
Old 02-19-2008, 10:25 AM   #9
bouncytruck
SKINNY TIRES RULE!
You can buy gas-tank specific patch material. It might be JB Weld brand, but don't just use the regular stuff.
bouncytruck 1972 K5
Old 02-19-2008, 10:39 AM   #10
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
More likely a venting prob.
In my own experience,no.
Used it in a "T" fitting I made for a return line when I installed my TPI fuel injection.
Before I had the return plugged into the vent line that's located beside the filler tube.
I couldn't fill the tank without getting sprayed with gas.
Since I made the "T" fitting I've had no problems.
I JB welded the brass fitting into the tubing to make this "T"
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-19-2008, 10:42 AM   #11
71swb4x4
71swb4x4's Avatar
I agree that it's a venting problem. I had the same problem on my Ford that I use to haul crap to the dump.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-04-2009, 11:52 PM   #12
myraley
myraley's Avatar
Say, BobbyK I am about to do the same thing (add a tee fitting to my filler vent hose for a fuel pump return line. Whats was the problem? Why wouldnt the gas just run back down to the tank?
myraley is offline   Reply With Quote
Old 03-05-2009, 12:13 AM   #13
BobbyK
BobbyK's Avatar
I had orig. "T'd" into the small vent line that runs beside the main fill tube.There was a short down-hill run that the return gas would collect.
So when I would try to gas up the vent line was unable to vent because a portion of the line was full of gas.
After I made the T you see in the above pic, and placed it in the main fill tube, I never had any problems with gas puking back at me while filling up.
Old 03-05-2009, 12:26 AM   #14
myraley
myraley's Avatar
Wow, that was a quick response. Thanks! Hmmm. I am carbureted, and the only reason I am adding a return line is because with my engine swap (a '79 into a '72 body), the fuel pump has a return line, while the truck originally did not. I have added a long piece of metal fuel line to the frame, next to the supply, and now am ready (or so I thought) to splice it into the vent hose that runs next to the filler hose (just like your photo shows). Does that vent line just run into the tank? If so, I dont think I would have a problem, since the return line is 1/4" and the vent hose is 1/2". It will just drain down into the tank. But if there are baffles in the tank, or some kind of filter or something that would prevent the gas from draining back in quickly, that could cause me the same problem you had. Do you know? I have been trying to look in there with a flashlight, and stick things into the opening (nothing metal, I dont want sparks!) but I cant tell....
Old 03-05-2009, 02:19 AM   #15
BobbyK
BobbyK's Avatar
No, there's nothing to block the flow in the tank or vent nipple.
I only had a problem because ,like I said, my tubing ran down-hill from the tank before it started back up to the filler neck.
The fuel collected in there once I shut off the engine.
Old 03-05-2009, 11:48 AM   #16
drunkbus
New Member
drunkbus's Avatar
My Blazer is original and does the same thing. You just have to pull it out some and find the sweet spot and run the pump on a slower setting.
drunkbus is offline   Reply With Quote
