Old 02-18-2008, 07:26 AM   #1
Question Another front end question
I have the entire front end out of a 73 C10 that will eventually go on my 70. Since I know I will want to rebuild it all, I was wondering could I just take all the pieces for the 73 and reassemble them onto the 70's saddle?
Not sure which way I am going to go, but I though since I had to rip it all apart and rebuild it before I actually use it that this might make sense, and just reassemble it onto the 70's saddle.
Is there any setback from doing it this way if it is possible?
Old 02-18-2008, 07:42 AM   #2
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: Another front end question
Those parts all will fit onto the 70 crossmember. Many have swapped like this the same as you and some choose just to use the entire crossmember from the donor vehicle. Use everything you can from the 73 like draglink,tie rods and such and just leave the crossmember in place.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-18-2008, 07:47 AM   #3
I may still just do the whole swap as I have everything, but since I modified the current saddle to run late model engine mounts, I thought just swapping out the pieces might be easier since I have to rip it all apart anyways..
