02-18-2008, 12:04 PM | #1 |
Resistance is Futile
hard-lined air ride..........
I was reading some of the air ride threads and saw many people talking about hardlines on the system. What fitting style is used?
I am putting a system together and have most of my hardware for tank and valves........using 3/8sNPT and planning to use 1/2" tube; unless someone convinces me hardline is better! Anyway, again, what fitting style is used to do hardline?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-18-2008, 12:42 PM | #2 |
Re: hard-lined air ride..........
you will need to look at compression fittings that use a single or a double ferrule.
Parker's brand name are A-Lok (double ferrule) and CPI(single ferrule). |
02-19-2008, 05:17 AM | #3 |
on my ranger i use copper line and press in fitttings
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
02-19-2008, 08:41 AM | #4 |
Heres some inspiration: (not mine) Looks much better than plastic IMO.
02-19-2008, 06:59 PM | #5 |
Nice pic. Looks like a flared connection and IMO the only way to go for a hardline system. Parker of Swagelock compression fittings should work just as well but at a higher cost I would think.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 02-19-2008 at 07:00 PM. |
02-20-2008, 03:53 AM | #6 |
Thanx guys......Iwas curious about this stuff. I had some tube fittings that were terminated and compression ferrulled (?). The fittings showed a DOT listing. I figured they were from a big-rig type application. NPT on the other side.
Thats some sweet looking work jlaird. Im going to stick to the tube due to budget constraints for now. I can change later if I want. I new people would have the info here.
02-20-2008, 04:13 AM | #7 |
I thought about using hard line, but it was much easier to use flexible tubing since I didn't take my body off the frame.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
03-01-2008, 05:27 AM | #8 |
Got a question. In another thread Nathan suggested when using hardline, use braided stainless between the compressor/tank, tank/hardline, and hardline/bags. I understand why to use the braided between the compressor/tank, but why the other places? The bags and tank seem like they would be stationary enough that a flexible line wouldn't be needed. Maybe its for maintenience??
Here is another pick I found. Look sweet! |
03-01-2008, 06:16 AM | #9 |
Yeah, could be........what about frame flex if someone is hitting the switches quite a bit??
03-01-2008, 10:25 AM | #10 | |
Pro-trash- Granberry's has all the necessary fittings and adapters to run the stainless line with A/N fittings.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
03-01-2008, 04:12 PM | #11 |
What is the price for a roll of stainless?
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
03-01-2008, 06:44 PM | #12 |
Summit has a 20 ft roll of 3/8" stainless for $31.95
http://store.summitracing.com/egnsea...=KeywordSearch Aluminum tube is about half the cost. 25 ft of 3/8" aluminum is $16.95 http://store.summitracing.com/egnsea...=KeywordSearch
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 03-01-2008 at 06:47 PM. |
03-01-2008, 09:40 PM | #13 |
soon to be bagged64sub
How hard is it to straighten out the rolls?
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
03-01-2008, 09:46 PM | #14 |
it's a pain in the ass ... damn near impossible to get it absolutely straight ... you would be better off using the short straight sticks of SS tubing versus the rolled type if you are going for looks.
do a search on ebay for 3/8 stainless tubing Last edited by Shane; 03-01-2008 at 09:47 PM. |
03-03-2008, 05:40 AM | #15 |
Hollister, CA.
Hardlines are the only way to go for a bullet-proof, custom looking finished product.
I used hardlines for many of my hydro and air-ride installs. Tubing is easier and much faster than hardline, obviously. But if you have the time, patience, and a quality bender....than the hard-stuff is the way to go.....that reminds me, that's what she said ! I use the double-flare with the sliding ferror and nut as shown in the first pic above. The only pic I have is that of the "Z069" -10 and -6 fuel lines (aluminum) - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
03-03-2008, 06:17 AM | #16 |
LAIDOUT
Those hard lines look sweet, but yea that has to be a ton more work.
I took lots of time making the bottom of my restorod clean but really the only people that have seen the bottom side of my ride besides me is the alignment guy. Course my ride is just a driver, no jackstands and mirrors at my shows : ) Last edited by BigSky71; 03-03-2008 at 06:17 AM. |
01-29-2009, 06:04 PM | #17 | |
My truck spends more than my wife, is that normal? |
01-29-2009, 09:04 PM | #18 |
maybe a dumb question, but can i just use compression fittings and not flair anything? i have seen plain ol ptc fittings with copper line but it looks scary. i have seen copper on big rigs and i dont think they use any sort of flaired end. info?
01-29-2009, 09:37 PM | #19 | |
Hollister, CA.
You can....many people do. Personally, I think it's 'ghetto'
01-29-2009, 09:58 PM | #20 | |
accepting donations
Not much copper used on "big rigs" for airlines. About the only place you will see a hard line airline is on kenworth airbags. and it's only a short section. Lot of the trailers have short section of steel tube going to the airbags. Either DOT plastic tubing, and braided stainless. EDIT.. some have a hardline right off the compressor with a union to the SS.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett Last edited by theyammieguy; 01-29-2009 at 09:59 PM. |
01-29-2009, 10:21 PM | #21 |
yes, there are flareless fittings. Swagelok brand is one of them. Parker also makes them by the name Ferulok. Russell also makes flareless fittings for fuel line, but not sure if they will work with air.
01-29-2009, 11:17 PM | #22 |
Hardline rules !!!!!!
www.bentcustomandperformance.com |
01-30-2009, 01:37 AM | #23 |
^^^^holy crap thats a lot of hard line.... looks nice
01-30-2009, 08:04 AM | #24 |
One day...
Wow those setups look really good!
01-30-2009, 01:45 PM | #25 |
Bentfab also does hardline for Nelson supercars twin turbo builds...take a look at his web site.
