I cant decide on which way to go with lowering my 83 C-10. Will shackels, hangers and spindles be the way? Or, go air?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: lowering
welcome to the board how much of a drop are ya looking for?
Dark Heart Motorsports
Re: lowering
if you are wanting to add hellacious performance in the future I heavily advise just dropping it... especially if you have a lead foot like most of us.
if you are going for show... air is teh way to go...
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
Cruzzzn' Vet
Re: lowering
Do you want a static drop or Air? static would be the cheapest way while air can get expensive. the quick way would be a flip kit for the rear and spindles and coils for the front, this is my 83 with a 4/5 drop, 2 cut coils in the front and flip kit on the rear
Re: lowering
If you're going with a static drop, 3/5 is the way to go. Djm suspension sells 3" spindles, plus you'll need them if you were to add air ride later on.
Mexican |
Re: lowering
thank you copper... that is something I had always wondered...
Insert Witty Text Here
Re: lowering
If you have, and plan to keep, 15" wheels, you might be better off with 2.5" drop spindles. With most 15" wheels (likek my 15X8 rally wheels), you have to do some grinding to your calipers, lower control arms, or both if you use 3" spindles. I opted for 2.5" to avoid those problems.
Shackles, hangers, and spindles will make it look about like mine. I have drop leaves in the rear, but they are supposed to give the same amount of drop (about 4") as hangers and spindles. If you want to go lower, do a flip kit with spindles, and add drop springs until you get to the right height. As far as air bags go, the only limit is the thickness of your wallet. ![]() For pics of mine, look in my photo gallery. There is a link to it on my truck page, which you can get to by clicking on my signature at the bottom of this post. Slonaker |
It Is What It Is,,,,
Re: lowering
Or just get the 3" LCA from DJM
![]() Easy bolt on, and ya get new LCA bushing done at the same time,,,,,
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den
Re: lowering
Did you use spindles or just cut the springs. If you did what kind of drop are they?
Cut the springs?? What about your ride quality???
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
![]() Join Date: Mar 2006
Re: lowering
I was about to ask the same thing. I went that route when I first got my truck and the ride around town as a DD was a bit rough, come to find out I was hitting the bumpstops on all but the smoothest roads. As soon as I found that out I ordered 2.5" spindles and 2" coils and havent had any problems since.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
#12 | |
lucky knuckles
Re: lowering
i'm about to drop $1200 on a set of used 20" foose spanks and i wanna get 'er dropped asap. if it was considerably cheaper i'd order em right now. i'm thinking it's $230-250 for 3" drop spindles? ..is that about right? DJM lca's easier to install than spindles? |
#13 |
Cruzzzn' Vet
Re: lowering
I had 2 coils cut out and an alignment kit installed which is the black bar sitting behind the alignment shims and longer bolts that keep everything in alignment, the bumpstops were cut off for free travel, I had this setup put in when I bought the truck new and has been troublefree since, i've only bottomed out once when I hit a rut in the road at speed and it was too late to brake
all this was before spindles and lowering springs for our trucks, still a nice ride, not rough at all.![]()
| Bookmarks |
