02-19-2008, 02:11 AM | #1 |
brake line t
How do you run a brake line t for a new set master cyclinder? Would like to upgrade to a dual master cyclinder, but no nothing of the line split "T" so I can hook up the front and rear Hope this makes sense?
thx |
02-19-2008, 05:01 AM | #2 |
Registered.........
Re: brake line t
Check out this post, it should answer your questions.
http://67-72chevytrucks.com/vboard/s...d.php?t=239100 Good luck, Pete
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
02-19-2008, 01:00 PM | #3 |
Re: brake line t
I believe if you follow the line down from the existime mc, you will come to a t that connects the L front, R front and rear. You want to get a plug for the rear line T fitting, so you isolate the front. Connect to the new MC using the old line. You now run a new line front the existing rear line you removed, and plumb it up to the other circuit of the MC.
02-19-2008, 09:32 PM | #4 |
Hollister, CA.
Re: brake line t
Yeap that link above was from my truck.
Just plug that tee, and run a seperate line to the rear line using a union. Need some pics ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 02-19-2008 at 09:34 PM. |
02-19-2008, 11:09 PM | #5 |
Re: brake line t
Can you snap a pic of the rear line conection? ( the old to new to master cyl line ) Thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
02-20-2008, 09:34 AM | #6 |
Re: brake line t
yes pics would be great, oh I suppose auto zone sells brake line, I'll have to have them flared or???
