Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-19-2008, 04:03 AM   #1
Dano69c10
Dano69c10's Avatar
Engines for LUV/S-10's?
Is this info correct?
1.8L 4 cyl (Isuzu)
1.9L 4 cyl (Isuzu)
2.0L 4 cyl (GM)
2.2L 4 cyl (GM)
2.4L 4 cyl (GM)
2.5L 4 cyl (GM)
2.8L 60 deg V-6 (Chevy)
4.3L 90 deg V-6 (Chevy)
Can someone correct or add the missing info?
Thanx
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-19-2008, 06:30 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Engines for LUV/S-10's?
I know they put the 151 4 cylinder in the S-10 . I think it was 2.2 ltr GM.
hotrod 80 is offline   Reply With Quote
Old 02-19-2008, 06:52 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
all the ??? ones are GM. the 2.0 thru 2.4 are basically the same, just progressive increasement in size.
68C15 is offline   Reply With Quote
Old 02-20-2008, 12:45 AM   #4
Dano69c10
Dano69c10's Avatar
I was just wondering which engine will go into my LUV with minimal amount of work. The V-8/V-6 swap requires a lot of fab work. I was going to go with either an Iron Duke 4 or a 2.8L 60 deg V-6.
'69 Fleet
Old 02-20-2008, 04:19 AM   #5
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
See if you can find a RWD Isuzu Impulse 2.0L motor. They are the same block (with punched out cylinders) as the stock engine, but the camshaft angle is corrected (stock Luv engines were retarded 4 deg).
The water pumps, head gaskets, intake manifolds, everything is all the same. Only differences in the two were the pistons, rings, camshaft.
If you can then find the Holley / Weber 2 bbl from a Pinto and get the adapter plate, you've got a screaming monster of an engine. JC Whitney still sells the dual port headers for the stock Luv as well.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 02-20-2008, 07:42 AM   #6
Dano69c10
Dano69c10's Avatar
Cool! I be on the look out, sounds like a simple swap and I can get rid of the Hitachi carb at the same time.
'69 Fleet
Old 02-20-2008, 07:52 AM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
Izusu impulse turbo swap ! The fab work to put a gm 4 cylinder is about the same as the v-8 .
Old 02-20-2008, 10:22 AM   #8
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Oh, forgot one thing in my above post - if you go for an Impulse motor, get one out of a turbo model, even if you're not going turbo. The crank, rods and pistons are all forged stock in the turbo motor versus cast in a non-turbo motor. Just rip the intake and exhaust manifolds off your motor and bolt them right on to the turbo motor.
Just for gawd's sake put the intake on the motor BEFORE you install it!! Getting the underside nuts on the #2 & #3 cylinders on the intake while the engine's in place are the biggest PITA you'll ever come across!! The EGR is RIGHT in the way. You end up putting the wrench on open end, using two fingers (no thumb) to move it a little, then flipping the wrench over the other way, rinse and repeat until you finally discover you can't get enough torque to seal the intake gasket and end up pulling the motor back out anyways!!
Darrin
RIP ESLL
Old 04-10-2008, 10:18 PM   #9
screwballl
Tonawanda 454
screwballl's Avatar
sorry to dig this back up but:
the Luv originally came with the Isuzu 1.8L 4cyl
MickeyD had the best option above... find an Isuzu V-6 and things will go much smoother
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
