That's right, it's Copper!!
I want a quiet truck!!!
I'm getting ready to take the truck down to the local exhaust shop and have the exhaust system installed. I want the truck to be quiet but at the same time I need mufflers that flow well.
I'm running a ZZ383 GM motor and will be installing elec. cutouts for those times I want it to be loud. Anyone have experience with quality mufflers that will meet my desires? |
I have a radical idea!
Re: I want a quiet truck!!!
Thrush Turbos or Flowtech Raptors flow decent and are mild. I have run them both on different cars and trucks and they are about the mildest I've found. They don't have the interior resonance that a lot of others have.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-19-2008 at 07:15 AM. |
![]() Join Date: Sep 2006
I have Magnaflow exhaust system and its quiet. I'm also putting cut outs on mine for when I want it loud.
knuckle buster..
![]() Join Date: Oct 2007
i know that dynomax and magnaflow are the best dyno/race proven flow through design out there,they are a flow through design using perforated pipe the same size as the inlet/outlets so that you dont compromise the flow. they also utilize high temp resistant ceramics and fiberglass for insulating against noise inside the actual muffler, around the pipe which is a benefit instead of baffles and chambers like a flowmaster runs. as for quiet... the dynomax's are a bit more quiet, and they both (dynomax and magnaflow)have really nice tone to them....price wise check out this linkwww.shopmufflers.com/, this will give you an idea price wise within a few dollars of what you might spend for your mufflers. i've been scouting the right set-up for my truck for about a week now.
i hope this helps!! flow and power vs noise and restriction ![]() |
Depends how much power you are going to make. I have the Dynomax Hemi Turbo mufflers in 2 1/2". That's about the quietest free flowing muffler you will find. If you need 3", you may want to look into some Dynomax RV mufflers, easy if you have a leaf spring truck. Here it is at Jegs:
http://www.jegs.com/webapp/wcs/store...10002_26260_-1 Walker actually has a catalong that shows flow rates so you can determine if a muffler will flow as much as you need. None of the other mufflers will be this quiet.
knuckle buster..
the only problem with those very very nice electric cut-outs is that when you run them on an engine putting out so much power and heat is that the valves and gaskets fail after about 9mo-1yr. i had these on a camaro with a 427 stroker in it. gave me 9 months first go around and the second warrantied set lasted about 1 year, thats when i asked the exhaust gods for an answer...... well, they said to eliminate the problem. 500 bucks later i ran just 3" pipe with cut-outs and flanges bolted shut. those to fail after some time. just some first hand experience i thought i'd share with ya. they are way trick and really scare the crap out of stop light would be racers when you open them up. but when they leak your car sounds like a 3 cylinder motor running open headers...lol
I went down to the local shop and told them that my truck would be a daily driver and I want it to be a sleeper. so we put magnaflow SUV type mufflers on it. we ran duals with 3" exhaust. Wen I get it back together all the way we will run it all the way out the back.
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
BlahBlahBlah
Have you looked into Flowmasters Hushpower mufflers? Go to hushpower.com to check them out. Ive heard good things about them.
The Hushpower mufflers look trick but the price, $$$$$. I was looking at the Dynomax Super Turbo Mufflers. Big difference in price, $52 for the Dynomax or $179 for the Hushpower.
The Dynomax ST's are definitely the quitest mufflers. A little too quiet for me.
I run Thrush Turbos on the 70 and with full pipes and 3"x18" magaphones it has a very nice semi-quiet tone, but is also very healthy sound at idle and certain speed ranges.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
Magnflow or Dynomax Ultra-flow are basically the same thing. I went with Magnaflows on my truck from hooker aero-chambers, and it is about 1/10th as loud as it used to be. I'll be putting up some before and after sounds some day.
X or H pipes help keep noise down too. |
a "quiet" truck?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#13 |
You got it, "A quiet truck", until I want to be heard!!
Steven, you need to see the truck before you pass judgment. |
#14 |
"X" pipes will help quiet things as well. Shown is a 2-1/2" system off stock manifolds. Mufflers unknown, but still in good shape. I can't hear the exhaust when I'm up at the front of the truck or when I'm driving, only when standing at the rear.
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) |
#15 |
ive got flowmaster 40 series ran out the back, its not loud at all in the cab. but i insulated the HELL outa my cab, lots of sound deadener, carpet pad an carpet , doesnt even sound like metal when you bang on the floor. its awesome!!..
#16 |
Prestige member Old Farts Club
X-pipe or H pipe will help allot
Hey sombodys gotta do it! ![]() |
#17 |
Aluminum slot wheels rule...
I've got headers, thrush turbos with 3 1/2" x 18" tips, and it's about perfect for me. Not too loud cruising, but will really TALK when u step on it.
#18 |
I think you would like the Dynomax #17749. It's a 2 1/2" offset in/ offset out with a 20" case. To me, they're perfect. Quiet, but plenty of volume when you "mash the gas".
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
#19 | |
knuckle buster..
i'm runnin 2.5 aluminized mandrel bent with an h-pipe to those st's dumping out turn downs before the rear end. its pretty deep at idle and gets kinda tinny and high pitch between 3500-7500 rpms.... i dont like em but it could be the turn downs!
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
#20 |
My personal experience is to get the pipes out from under the car/truck. Good sound insulation is a must! I've got header mufflers on right now, with about two feet of 3" pipe dumping just aft of the cab (temporary set up) And as loud as that can be resonating through the cab at the wrong rpm/load, I can hardly hear the exhaust over the road noise at highway speeds
#21 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
I had the Dynomax Super Turbo's a few years back on my Cutlass with a Rocket 350 and headers, and it sounded great, but by no means was it quiet.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#22 | |
Active Member
Sonny New Project: 67 Small window SWB 2006 Crew Cab Silverado LT ![]() ![]() |
#23 |
67L30wgn
where did you get the Exhaust and X Pipe done at ? I am cross the bay and need to get my exhaust done. |
#24 |
![]() Join Date: Apr 2005
The X setup is very nicely done.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#25 |
blood type; Retumbo
they are great! I have 1 on my truck. that's right, ONE. I ditched the heddmans and 2 1/2" x 12" glass packs a year ago and went to 80's style bottom log manifolds. the pipe bender guy made up a Y pipe and put the 2 1/2" Hushpower just before the axle with a turn-out behind the LR wheel. then I went on a 1500 mile road trip pulling a big U-haul trailer. no power difference between before and after. it is quiet inside but has a noticeable tone at the rear, until I get on it. then it talks.
