02-19-2008, 08:22 AM | #1 |
go cyclones
master cylinder
Has anyone upgraded or put a newer master cylinder in a 67-72? I stripped my vehicle down and the one I have is pretty grimmy and rusted. When I reassemble it I would like to put a newer one on, possible a 3/4 ton for a little more braking power to handle the bigger wheels. I tried a search but didn't come up with anything
02-19-2008, 08:23 AM | #2 |
Re: master cylinder
i know one from a 87 wont fit..but thats the only help i can give...
02-19-2008, 10:25 AM | #3 |
Re: master cylinder
not sure a bigger master cylinder is going to give you more braking power. You may want to try power brakes. That seems the best way to add more braking.
02-19-2008, 11:17 AM | #4 |
its all about the +6 inches
Re: master cylinder
a 3/4 ton or one ton won't go on without some replumbing, they are plumbed bass ackwards compaired to the 1/2 ton.
02-19-2008, 07:38 PM | #5 |
go cyclones
Re: master cylinder
Thanks guys, if it isn't going to be straight forward, I will just have to see if I can get a cleaned up one.
02-19-2008, 08:41 PM | #6 | |
Active Member
Re: master cylinder
02-20-2008, 09:40 AM | #7 |
Re: master cylinder
i had to replace my master cylinder a couple months ago.... midas wanted 100 some dollars for a new master cylinder and to bleed it....i went to down to autozone and i got a rebuilt one for $14...took it to my uncle who knows about brakes and he put it on for me and i have had no problems with it
02-22-2008, 02:38 AM | #8 |
Re: master cylinder
yeah just go to your local parts place and get a new one, i did for like 30$, works good, you must be thinking about using a 3/4 ton / 4x4 booster, i have heard they are a dual diaphram booster that will give you a better assist that the single diaphram c10 variety. the only way you will gain better braking ability is to upgrade the size of the disc, size of caliper (pad) or clamping force of the caliper (multiple pistons), same theory on the back. the booster is only an assist, it helps your leg. this can translate into better braking i suppose, because you can jam that pedal down faster than no booster, so you may stop sooner than without a booster. good luck.
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
02-22-2008, 03:36 AM | #9 |
Re: master cylinder
grab a hydroboost unit out of a junkyard. I found a complete setup with the pump and all for $75, which I havent yet had time to install. Do a search about it, you should return several threads. The brake system runs off your power steering pump and works much better than P/B
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
