Old 02-19-2008, 09:01 AM   #1
Chevyholic
Will it run today?
Chevyholic's Avatar
Question Help Electrical Dummy
So, I can add new circuits and install all kinds of lighting and electrical services to my home, but haven't figured out how to transfer that knowledge to a car. Here's my problem/question:
How do you keep your lights from dimming and windshield wipers from slowing when going from running speed to idle? When I come to a stop and my wipers are on the slower speed they have a hard time even tracking across my windshield and will sometimes come to a complete stop due to the friction. Will an upgraded alternator help this problem? If a new alternator is the answer, any suggestions for a replacement? Mine is currently externally regulated, so I'd like to switch to internal, but see all kinds of options for amperage, but don't quite know how much is enough, or too much.
Thanks!
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 02-19-2008, 09:09 AM   #2
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Re: Help Electrical Dummy
minimum 100 amp powermaster or delco=120-200 bucks, a new battery would also help. red top optima=130-150 bucks, also run some relays for your headlights. 1 for each high and low beam, HUGE difference!!!!
72swb_327stroker_? is offline   Reply With Quote
Old 02-19-2008, 09:26 AM   #3
cameeks
Long Fleet Club
cameeks's Avatar
if you have a long water pump you can get an alt for a '84 Camaro 305. That is what I'm running now. I got mine at Orielly's with a life time warrenty for $85
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 02-20-2008, 01:01 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Make sure you have a good ground strap run to the cab.The flux you are getting is from the alt. output dropping when you idle but even if the alt. is weak the battery should sustain the voltage.So check grounding straps from battery to engine, frame and body.Is your battery in good shape? Not having to jump it off or anything. A bad battery can cause this too.
sneakysnake is offline   Reply With Quote
Old 02-20-2008, 01:59 AM   #5
Chevyholic
Will it run today?
Chevyholic's Avatar
I think the battery is ok. Simply meaning it starts right up every time. The ground from battery to the block is in good condition, but I will check the other straps and check the voltage of the battery with and without the lights/wipers on. Thanks!
Old 02-20-2008, 03:18 AM   #6
neonlarry
neonlarry's Avatar
Its mostly the voltage at the accessory your trying to use thats the problem. It gets kind of low after going thru all the ancient wiring not to mention an alternator that can barly keep up with the load.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-20-2008, 03:26 AM   #7
463
463's Avatar
link:http://67-72chevytrucks.com/vboard/s...d.php?t=119379 help line 463
463 is offline   Reply With Quote
Old 02-20-2008, 03:26 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a couple places to start. OK four
http://www.6066gmcguy.org/charging.htm
http://www.chevelles.com/techref/tecref14.html
http://www.alternatorparts.com/cs130_sbpage1.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
