02-19-2008, 11:21 AM | #1 |
350 Build Progress
Well this weekend, I got a chance to start working on my 350 build for my truck. This motor will be used until I get my big block done the right way. The 350 will be topped with Vortec Heads and 268H Comp Cams Camshaft. I am amazed at how much I spent on this mule motor... I am close to 2k but I just had to do it my way so that in itself has driven the price up! The problem I ran into so far is two cans of the wrong color paint... I have some repaint to do in the morning....
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! Last edited by 70C10Step; 02-19-2008 at 11:34 AM. |
02-19-2008, 11:25 AM | #2 |
knuckle buster..
Re: 350 Build Progress
that looks awesome!!!!!!! great job, can't wait to see it in the engine bay!!!
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) join the the smilies fight club |
02-19-2008, 11:38 AM | #3 |
Yes, I know I have to make sure the engine bay is clean also.... I plan to put some time into the frame and engine bay... This is my first Chevy build so the guys on the base I am stationed at are watching my every move. I have a 65 and 66 fatsback mustangs that I am usually working on. For me to start on this truck is a real change in direction for me... I am learning a lot about Chevy engines etc.... it has been a fun experience so far....
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
02-19-2008, 11:49 AM | #4 |
knuckle buster..
awesome you could possibly talk someone into trading you a few shiny pennys for those fords that you don't need anymore, and you could invest that in your real project. maybe some spray paint for the engine bay in(the chevy)
02-19-2008, 11:54 AM | #5 |
Looking good (love the valve covers!) and I'm sure it'll be a great combo- that cam and those heads are a great match!
02-19-2008, 01:33 PM | #6 |
Thanks Billa, I followed your advice you gave me early in this build. It really made matching up the parts pretty easy.... I just needed a solid combo... Now I got to figure out do I go 350 turbo or 700r4.....
02-19-2008, 09:00 PM | #7 |
If you are going with a big block later you might want to consider the turbo 400.
69 Chevy 4x4 383 Power |
02-19-2008, 10:26 PM | #8 |
ight now I have a 350 turbo, a 700r4 and a turbo 400. I got these all from different deals off ofcraig's list. You are so right about the turbo 400 but I need to find a place to rebuild it because I do not know its working condition...
02-20-2008, 12:43 AM | #9 |
When you're done with that 350 and want to put in the BB, you might pass that motor down to one of your local neighbor board members... (I wouldn't want it to go to waste)
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
02-20-2008, 12:51 AM | #10 |
That seems like a very reasonable option!!! Keep in touch, you never know when the BB project will take off faster than it should. Just sent my heads over to a buddy in phoenix for a port job... I have a 454 now but I would love to get my hands on a 396/402 truck block...
02-20-2008, 01:05 AM | #11 |
mini truck racer
The motor in the second picture does not have vortec heads .
02-20-2008, 01:21 AM | #12 |
In response to the heads question. This is what I bought:
CHEVY 350 SMALL CHAMBER HEADS BEST STREET These Are Custom Rebuilt set of Cast iron 64cc " Heads, First Gen Vortec Heads Heads Will fit 1955 To 1995, Will Fit 12 bolt Intakes POWER 2 ENGINEŽ MACHINE LABOR includes: PER 4-angleŽ valve job • 4 Angle Valve Job Cut 1.94" Int,1.5" Exh valve size • Machined for 460,470,480 CAMS • Install Per SS High Performance 900 springs to installed correct heigth • These can Handle up to .500" valve lift • Both Heads Mill Matching Resurfaced Heads • All 16 valve guides Replace Heavy duty thick wall • Valve guides custom cut for posi-seals • Heads are Jet vatted, magnafluxed to check for cracks • Both Heads are Tapped out on All Bolt Holes • Heads Will Fit 12 bolt Intakes Bolts POWER 2 ENGINEŽ ENGINE PARTS includes: • New Per ss Spring set 900 series • HD 1.94 Steel Stem intake valves • HD 1.5 Steel Stem steel exhaust valves • Premium positive seals polycrylate • Note: You can use Steel Stamped or Roller Rockers with These Heads • Note: Pushrods Size 5/16 This Power 2 Engine Head Combination would be GREAT Replacement Mild To Hot Street This will be a Excellent Set for your everday Driver, Will Run on Premium unleaded fuel I am new to the Chevy world but this is what I bought! I stand corrected if I was sold something else! All I know is it will serve as a good mule motor for now....
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! Last edited by 70C10Step; 02-20-2008 at 01:28 AM. |
02-20-2008, 03:07 AM | #13 |
Whatever the heads are, that 350 is going to be BAD A$$. Cant wait to see the truck! Good work-
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
02-20-2008, 08:12 AM | #14 |
Those definately arent vortec's. Vortec heads require a different intake with vertical rather than diagonal bolts like this one:
Check the casting number. I actually made the same mistake when I was young and ignorant- bought a set of what I thought were vortec's but turned out to be TBI's (good thing I only payed $250). On TBI heads, the center bolts through the intake are vertical while the forward and rear-most bolts are diagonal. Nothing wrong with them, they just are going to flow as well in the upper rpm range as vortec's would. Let us know what you find out
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
