Old 02-20-2008, 01:26 AM   #1
Tynee
I miss this truck.
Tynee's Avatar
NOS Steering column parts question
I'm trying to buy a steering column, but it needs a lower bearing. When I asked the seller where a guy would find such an animal (after checking a couple of parts houses), he said he had a NOS bearing, but he didn't know if its lower or upper. Part # is 7805790. Anybody know how I can find out if this is the right bearing, or where i can FIND replacement bearings?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-20-2008, 03:03 AM   #2
stope4
Re: NOS Steering column parts question
See if he will take a picture of both sides of the bearing and measure the diameter of the top and bottom. Send me the pictures using my contact info. I will then compare to my tilt. I think the bearing is visible at the bottom of the column.
stope4 is offline   Reply With Quote
Old 02-20-2008, 03:10 AM   #3
Tynee
I miss this truck.
Tynee's Avatar
Its a non-tilt column, would that change the lower bearing?
Old 02-20-2008, 03:36 AM   #4
stope4
I'm pretty sure the tilt and non-tilt lower bearings are different. But I have both columns
Old 02-20-2008, 08:24 AM   #5
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
The bearing is still available from GM it is different from upper bearing. Tilts and non tilt use the same bearing but use different housings.
KevsClassics is offline   Reply With Quote
Old 02-20-2008, 09:31 AM   #6
dan42
dan42's Avatar
I think both Brother's and LMC have them. I just bought a pair from one of the two.(upper and lower).
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
