02-20-2008, 02:10 AM | #1 |
Blower motor replacement
It looks to me like the hood hinge has to come off to replace the blower motor (72 K5 w factory AC). Anyone know for sure?
02-20-2008, 02:56 AM | #2 |
Re: Blower motor replacement
not necessary, but makes it a lot easier (from what I have read)...
See if this helps (it is for a non-A/C though) http://67-72chevytrucks.com/vboard/s...ad.php?t=69812 |
02-20-2008, 04:06 AM | #3 |
I just take the hinge off, with or without a/c. Its quicker, and easier.
02-20-2008, 08:47 PM | #4 |
ARe you sure the motor is bad? Many of the A/C trucks loose one or two of the speeds due to faulty grounds or bad relay over the heater box behind the glove box. I think 9 of 10 trucks I have parted out have had mice nests or mice damage to the little barrel fan on the motor~~~. Huck
02-21-2008, 01:38 AM | #5 |
Future TOTM Winner
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
02-21-2008, 10:42 AM | #6 |
The motor works. I'm just tired of the squealing bearings.
02-21-2008, 12:19 PM | #7 |
I just pulled mine. It was really easy. I marked the hinge with chalk to make sure I could line it back up. I propped up that side with a broom stick and took off the hinge. You may have to pry the fan motor off. The whole job took like 20 minutes and I did it by myself.
Hope that helps |
02-21-2008, 10:10 PM | #8 |
Thanks. I might get around to it this weekend.
