Old 02-20-2008, 08:33 AM   #1
mtburg71
mtburg71's Avatar
Questions about Hood
Ok, I have question about the under hood supports. Should I spot weld them to help strengthing the center of the hood. Arrows pointing the area in mention. This hood is on a 64 GMC SWB.
Also have an alignment issue, with the hood closed, the center of the hood sits about a 1/2" below the hood cowl where the wiper arms are. See my photo editing skills with MS Paint with the arrows pointing to the area. Any suggestions or ideas?
Pics are provided. Thanks in advance for any and all help.
Mike
1964 GMC SWBFS
2005 Dodge Magnum RT
mtburg71 is offline   Reply With Quote
Old 02-20-2008, 09:26 AM   #2
David Flores
David Flores's Avatar
Re: Questions about Hood
No. don't spot weld them. They make pads that go between the brace and the hood. they control hood vibration and adds strength.
do you happen to live off of west adams?
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 02-21-2008, 06:21 AM   #3
kris's66lwb
resident wrencher
loosen all the bolts that hold the hood to the heinge and then close but dont latch and yank then tighten then readjust stricker and stricker plate
kris's66lwb is offline   Reply With Quote
Old 02-22-2008, 01:42 AM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
From the second picture, looks like he needs to loosed the bolts that hold the hinge to the inner fender and lift them up. That sets the HEIGHT of the hood to the cowl panel.
As for the supports, don't spot weld them. Get the sponge rubber cushions for them....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-22-2008, 07:50 AM   #5
mtburg71
mtburg71's Avatar
Got it, don't spot weld them. I held off from doing so.
The second pic doesn't have the hood all the way shut, but when it is shut and the hinges are lifted up still have that 1/2" height difference. The only thing I didn't adjust was the hood stops closest to the cab, dunno if that will help close the gap any. Any other suggestions or recommendations. Thanks
1964 GMC SWBFS
